power loss from 2k-2.5k rpm's
Old May 26, 2008 | 11:40 PM
hot_wax_tree's Avatar
Hey i have been having a power loss between 2k-2.5k rpms under normal acceleration. has anyone had this problem? it is not a significant loss just a little bit. but noticeable if you drive 500miles a week like i do. it happens in all gears accept 1st and 5th. I also think my clutch is on it's last leg if that has anything to do with it.
any advice is helpful.
Thank you
Jake
Old May 27, 2008 | 01:46 AM
cedric's Avatar
Check if the clutch is slipping. Symtoms would be - Engine revs but car wont pull properly. This will be noticable specially in higher gears and up hill.
Old May 27, 2008 | 07:32 AM
ruckus1027's Avatar
hey man you would have to be more detailed than that to really narrow it down to a handful of things
what does the rpm do when it looses power, does it stop or drop? is it a sudden jerk-ish loss of power or kind of a just not pulling feeling? is it all the time or intermittent? you know stuff like this let us know
Old May 27, 2008 | 08:42 AM
It is not a slipping feeling but it just kinda feels like it isnt pulling as hard as it does before 2k and after 2.5k and it is a constant feeling every time. its not a huge power loss it is just a little bit.
I am pretty sure it's not a clutch issue but I said that to just leave it open
when I am driving it just pulls normal, then once I hit 2kit kinda slouches a little bit for 500 rpms, then it pulls normal again. it's kinda like really weak turbo lag but for only 500rpms. if that makes sense.
Old May 27, 2008 | 09:33 AM
ruckus1027's Avatar
does it only hit for like almost a split second then theres power again? maybe coils or plugs?
Old May 27, 2008 | 11:00 AM
I was thinking that I guess i will check the plugs today but it will do it the whole time I am between 2-2.5k
Old May 27, 2008 | 07:00 PM
iDuty's Avatar
Is it any better when the engine is cold? (I don't mean freezing cold, just cooler than full operating temperature.)
I find my 97 gets noticeably weaker (never misfires, let's not get into tune up) in that RPM range when it is thoroughly heat soaked in slow traffic. My guess it that the intake gets hot enough that I have to open the throttle wider to get the same mass of air into it.
Old May 27, 2008 | 07:36 PM
B_Eaze's Avatar
I have the same problem, check your exhaust (more specifically your flex pipe) might be a hole. Thats y i'm loosing power on the low end, my flex pipe is a mess but i have no time to fix it (screw auto shops)
Old May 27, 2008 | 07:44 PM
maximase86's Avatar
I love lamp.
I'm thinking coils or plugs need a changing...maybe a vacuum leak. How does compression look?
S
Old May 27, 2008 | 11:31 PM
I changed my plugs today they had carbon build up on them and put in some ngk irridiums. I dont know about compression I would assume fine. but I want to check if I have a vacume leak but I have never done that before i just use a fog machine and let it go all over the engine and see if the fog moves in any spots? right?
Old May 28, 2008 | 12:12 AM
beez5spdmax's Avatar
thats funny use a fog machine how is that going to work when the fan turn on even if u disconnted them that still would not work.are u going to a club incase u dont understand what a club is because u have problem understanding slang i mean a disco tech. save the fog machine for the clubs!! :sprint2 p.s stop being cheap and put 93octane gas. have fun in the mountains where your from yeeee haaaaa
gigabyte
Jan 6, 2017 06:05 PM
Forge277
Jun 13, 2016 09:26 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Need help
23
Oct 2, 2015 08:56 AM
zmcneely13
Sep 26, 2015 02:26 PM
