Trouble starting
Old Jun 6, 2008 | 08:59 AM
Dark99GLE's Avatar
Trouble starting
Recently my car has been having trouble starting, It starts right up with no problem 60-70% of the time and the battery is new, so that's not the problem, basically it just sounds like it's having a hard time turning over, I didn't know if this is the starter(please no) or what. Any suggestions would be great, also, how much would I be looking at spending on a new starter?
side note, it runs great when started, dunno if that's relevant or anything, but yeah
Old Jun 6, 2008 | 09:06 AM
abomb1987's Avatar
how many miles you have on your car?
does it just sound like the started is not spinning fast enough?
Old Jun 6, 2008 | 09:12 AM
Dark99GLE's Avatar
I've got 128,800 on the Maxima, I don't hear anything unusual except the engine having trouble turning all the way over, I'm not great at diagnosing problems, and I don't want to take it to the stealership to get it looked at.
Where is the starter anyway?
Old Jun 6, 2008 | 09:26 AM
ajcool2's Avatar
http://www.vqpower.com/v2/infusions/...?article_id=94
Took me about 45 mins to replace mine. Next time it will be less.
Old Jun 6, 2008 | 09:30 AM
Dark99GLE's Avatar
thanks!!
How much would I be spending on a new starter?
Old Jun 6, 2008 | 09:32 AM
ajcool2's Avatar
thanks!!
I got mine from autozone for $170 and a lifetime warranty. It did go out on me last year and I took it back to them and they gave me another one free.
Old Jun 6, 2008 | 09:33 AM
QNO_A32's Avatar
i paid like 110 120...good luck its easy and clean the grounds while your in there!
Old Jun 6, 2008 | 09:36 AM
Dark99GLE's Avatar
awesome, I was dreading it because some guy told me it was under the IM, which sounded really odd to me
thanks for all the help!!
Old Jun 6, 2008 | 06:59 PM
QNO_A32's Avatar
under the IM thats funny. its gotta be near the flywheel, take off the airbox and look down.
Old Jun 6, 2008 | 07:17 PM
ZX9RBART's Avatar
If it starts 60 to 70% of the time with no problems I would guess that the starter is fine. Mine would usually start fine when cold but when hot would crank for a long time at lower speeds and kick back violently at times. A simple 8awg wire from battery negative to one of the starter bolts cured it instantly. Over a month of perfect starts since adding 1 simple cable. (and its alot cheaper than a starter)
Old Jun 6, 2008 | 07:49 PM
Feldman's Avatar
sounds like the battery to me. Even though it is new, i would at least have that checked out before you go and replace the starter.
Old Jun 6, 2008 | 08:26 PM
mansurxk's Avatar
that's related to the issue with manual transmissions i think. i think the auto trans has a much larger area of grounding. worth a shot though.
Old Jun 6, 2008 | 08:38 PM
ZX9RBART's Avatar
I just thought of it because my trans has never been out so that killed the "dirty surface" theory.
Old Jun 6, 2008 | 09:30 PM
Dark99GLE's Avatar
woo, starter installed, starting much better
bryants95max
Oct 2, 2015 12:52 PM
QueensMAX
Sep 15, 2015 04:14 AM
markevans999
Sep 10, 2015 04:29 PM
trungg86
Sep 4, 2015 04:58 AM
