Trunk will not open
Old Jun 16, 2008 | 01:50 PM
jattdemax's Avatar
Trunk will not open
I did a trunk swap on my 95 to a 97-99 about a month ago. I changed the latch on the trunk from my 95 trunk to make it fit. Today my trunk wouldnt open. I can hear it clicking, but not opening. I need to get in there! how can I open it?
Old Jun 16, 2008 | 01:56 PM
hot_wax_tree's Avatar
take out the rear seat then the pannel in the way it's like a couple screws then find the latch or wire what ever is eposed and open it from there.
or if you know for sure that it is un latching then just pull it hard and see if it doesnt open other wise just take out the back seat like I said.
the bottom of the back seat has 2 hooks you need to pull to un latch the coushon
good luck
Old Jun 16, 2008 | 02:16 PM
MaxGordon7's Avatar
my trunk sticks now, i already have to pry it from the bottom with fingers. Ive looked at it for an hour, dont know if the motor is going bad or what.
Old Jun 16, 2008 | 02:24 PM
jattdemax's Avatar
good luck
i will try with taking the rear seats out. i still hear it clicking, so i know the motor, or even a fuse is still intacked. it just wouldnt unlatch.
Old Jun 16, 2008 | 02:50 PM
2da mizzax's Avatar
the bottom bracket is misaligned. the smallest amount will prevent the trunk from opening.
Old Jun 16, 2008 | 06:07 PM
AEMAXIMA01's Avatar
Did you accidentally lock the trunk out? There's a lock on the latch that could be engaged.
Old Jun 16, 2008 | 06:15 PM
Bandfan1024's Avatar
This happened to me last week. All I did was put my fingers in the bottom of where the trunk connects to my car. I wiggled my fingers a bit and had to push a loose switch up into place.
Hope it helps
Old Jun 16, 2008 | 06:20 PM
Hexon's Avatar
Mine wouldn't close yesterday. Should we blame trunk monkeys?
I normally have to push the button once, pull up, then push again to open mine since the dynamat weighs it down and causes it to stick.
Old Jun 16, 2008 | 09:56 PM
jattdemax's Avatar
Hope it helps
how did you get you fingers in the bottom of where the trunk connects? did you take out your rear seat?
Old Jun 17, 2008 | 01:13 AM
NismoVQdet?'s Avatar
this is weird mine just all the sudden wouldn't open either i could here it clicking but nothing was happening.. tried pulling it from the bottom tried the key.. finally i just turned the key as hard as i could without breaking it and it opened.. i think sad from the beach and a bunch of dust got in there and jamed it up.. took some WD40 to it a couple times and haven't had a problem since..
Old Jun 17, 2008 | 03:42 PM
kevs95max's Avatar
take the rear seats out and unlock it from the inside there is a lever you might have engaged
Old Jun 20, 2008 | 10:37 PM
MaximusTheGreat's Avatar
I put the key in and turn my trunk opens every time.
J/K actually i didn't get a fob with the car. good luck
Old Jun 20, 2008 | 10:50 PM
arrocha87's Avatar
being as i dont have a key cylinder just a hole it would suk if mine didnt want to pop open!
Old Jun 21, 2008 | 10:26 AM
eclypsecl's Avatar
I had a similar problem, didn't feel like removing rear seats. Took a skinny plastic proom and with the end plastic tip wiggled the latch through the arm rest hole. Usually our cars have a mandatory manual release in the trunk right? I hit that latch and pulled up on the trunk..and it opened
REDinLV
Aug 15, 2024 12:30 AM
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
MaxiNoob98
Oct 2, 2015 10:13 PM
mrgooch
Sep 21, 2015 08:43 PM
