front motor mound problem
so were my front motor mound sits rutsed out and know my engine is jus sitting on there with no support it still runs like a baby but im worried that it might just fall out or something so i was told that my only 2 options are going to the junkyard and cutting the front frame from a junker or getting a pieace of meatal on soldering on there i jus wanted to run it by u guys to see what u think
you mean the lower radiator support? if so, yeah, you can have a new one welded in. labor will probably be around $400. the support itself from nissan, IIRC, is about $130. or, you can also have a piece of steel welded in. I recently had this done because the rad support that the shop used when they repaired my car was a cheap aftermarket one. it broke again right where the crossmember bolts up to it. I took it back to them and they repaired it by welding in a new piece of steel and bolting the crossmember back in place. so far, it's holding up fine. other than those two options, i can't think of anything else really that you can do to fix this.
vingodine
45
May 21, 2016 12:46 PM
Finkle
Sep 27, 2015 09:53 PM
