Anyone have some type of Performance meter/ MPG meter on their car?
Jun 24, 2008 | 08:21 PM
I've been driving a lot of newer cars with MPG meters and found that I can get a better gas mileage if I know what the MPG is, long story. I was thinking about getting something like this for my maxima
http://www.amazon.com/ScanGauge-Comp...4362525&sr=8-1
Has anyone had any experience with any of these are they any good? I've never known anyone to have one. Can I see more than just gas mileage such as maybe specific sensor readings? I was interested in this or maybe some software for a laptop doesn't anyone know any good software?
Jun 24, 2008 | 08:27 PM
Not a bad price since it can check ecu codes and all that good stuff. I don't know how accurate the mpg will be. It is much more accurate to reset your mileage each tank and just divide the miles traveled by the gallons filled up. Though this only works if you fill up the tank to the max everytime
Jun 24, 2008 | 08:31 PM
i was wondering the same thing.....where would this plug into....
i really like this thing
Jun 24, 2008 | 09:12 PM
i wonder how it would measure hp?
Jun 24, 2008 | 11:54 PM
Quote: i wonder how it would measure hp?
If I had to guess, it can measure engine load, so maybe you input the vehicle's weight and from there it calculates it based on engine load, the weight, the rate at which the vehicle is accelerating (since it measures speed), as well as RPM.
In theory I bet this could be calculated based off those variables, except if the car is going up or down a hill I can see that throwing it off.
Jun 25, 2008 | 01:05 AM
You can use a vacuum/boost guage! The vacuum side is what you'll be using, tilt the throttle to read the highest vacuum and that will be your sweet spot! You can also find those MPG guages @ JcWhitney....I'm gonna be honest, I don't dog the crap out of my Maximas but I can only drive it like an old lady for a few days!!!!
Jun 25, 2008 | 05:19 AM
I can't use it, my 96 isn't compatable with OBDII
and I think that the "cost of tank so far" feature would get depressing
Jun 25, 2008 | 05:39 AM
What makes you think your 96 isnt obd2? All/most cars in the US are obd2 96+
Jun 25, 2008 | 06:05 AM
Quote: What makes you think your 96 isnt obd2? All/most cars in the US are obd2 96+
ALL cars/light trucks sold new in the USA from 96- present have OBDII. Cars out side the US may not, learned that one the hard way.
Jun 25, 2008 | 06:22 AM
Quote: i was wondering the same thing.....where would this plug into....
It plugs into your OBD2 hookup near the fuse panel.
Jun 25, 2008 | 06:26 AM
Quote: ALL cars/light trucks sold new in the USA from 96- present have OBDII. Cars out side the US may not, learned that one the hard way.
And Nissan was ahead of the game, as all 4th gens, (95 included) are OBDII.
Jun 25, 2008 | 07:17 AM
Quote: And Nissan was ahead of the game, as all 4th gens, (95 included) are OBDII.
True story.
Jun 25, 2008 | 08:36 AM
any one gonna buy it?
Jun 25, 2008 | 08:40 AM
Quote: any one gonna buy it?
This isn't ro shambo. I'm not going first.
Jun 25, 2008 | 08:43 AM
Quote: Anyone have some type of Performance meter/ MPG meter on their car?
I have an RPM gauge!
Jun 25, 2008 | 11:31 AM
Chrysler did it in 94 on the LH cars , and GM did it in 94 on the F-bodies as well IIRC.
I think most OEs did it on cars that were near their redesign, but didn't neccessarily put in the connector like Nissan did.
I still prefer to use the consult port.
Jun 25, 2008 | 12:37 PM
I have a few friends with OBDII scanners and they don't fit the plug I have near the fusebox
The scanners that the autoparts stores have don't fit it either
the guy at autozone told me I was OBD 1
do they just have the wrong scanner?
Jun 25, 2008 | 01:18 PM
Quote: I have a few friends with OBDII scanners and they don't fit the plug I have near the fusebox
That's because the OBDII connector is next to the glovebox.
Jun 25, 2008 | 02:45 PM
Quote: That's because the OBDII connector is next to the glovebox.
No, it is in the standard OBDII location. to the left of the steering column under the dash. Below the fusebox as shown in your illustration.
only 95 has it in a different location.
Jun 26, 2008 | 01:19 AM
I must be speaking of some old school MPG meters? Sorry!
Jun 26, 2008 | 06:34 AM
Quote: No, it is in the standard OBDII location. to the left of the steering column under the dash. Below the fusebox as shown in your illustration.
That whats I meant, I was referring to 95's... Didn't see that he had a 96
The MPG meter on the A33B is off by 12-15%, and when you start modding, it gets worse.
Jun 26, 2008 | 07:17 AM
Quote: That whats I meant, I was referring to 95's... Didn't see that he had a 96
dam, that's a large margin of error
Jun 26, 2008 | 08:22 AM
Quote: dam, that's a large margin of error
2 -4 MPG on the high side.
4 MPG on a 24 MPG typical (calculated manually) =~ 16%, so, yup, worst case scenario.
Mine is even worse now since I've added Z33 injectors and an AFC.
