New Auto Climate Control LED Upgrade
Old Jul 6, 2008 | 12:16 PM
Reece616's Avatar
After checking out the write-up to change the climate control lighting to LEDs I decided to try it myself. I followed this how-to, but it seemed strange to me to make the LEDs run off of a separate source rather than the power source the original bulbs actually ran off.
To complete the job I used:
4 LEDs (they can be 3mm or 5mm, I've done this with both and they both work fine)
4 resistors (i got these with my LED purchase on ebay, many auctions come with them)
Solder
Phillips screw driver
Small flathead screw driver
Butter knife
Needle Nose pliers
1. Follow Step 1 on previously stated how-to to remove climate control from the vehicle. I used the butter knife and flat head screw driver to un-clip the climate control pieces. It says to remove small brown plastic pieces, mine were blue.
2. Remove the little bulbs from the brown or blue bulb holders with pliers and/or flathead screw driver. Now you should have this
3. Slide LED into bulb holder,
making sure the positive lead is closest to the "2" in "V-2"
4. Using the needle nose pliers and/or screw driver, bend the negative lead of the LED down, through the notch in the bulb holder, and then back down to the back of it and bend in over so it stays in securely.
5. Next, take a resistor and using the needle nose, bend the resistor like so.
Old Jul 6, 2008 | 12:17 PM
Reece616's Avatar
6. Solder the resistor to the Positive lead of the LED as shown, and clip off the extra leads afterwards.
7. Repeat Step 4 for the Positive lead (the long leg of the resistor) and bend it around the bulb holder to secure it. After you should have this.
8. Do this for all 4 bulb holders
9. Put the newly modified bulb holders into the circuit board and twist them into place. Since they are modified, it may be difficult to twist them with a Phillips screw driver, I used the needle-nose to do this.
10. After they are all in, connect the back of the Climate control to the front making sure the LED leads/resistors do not get in the way. Once it is back together, reinstall in your car, turn on the lights, and enjoy.
Night shots coming soon!
Old Jul 6, 2008 | 12:18 PM
G4nismo's Avatar
cool
Old Jul 6, 2008 | 05:21 PM
JSMax's Avatar
Sold
in for the night shots...
Old Jul 6, 2008 | 06:01 PM
fat_kid's Avatar
pics of it in please
Old Jul 6, 2008 | 06:03 PM
maxx0831's Avatar
nice, real nice, cant waitto see the night shots
Old Jul 6, 2008 | 07:32 PM
WhiteA32's Avatar
Subscribed, waiting for moar pix
Old Jul 6, 2008 | 09:10 PM
Reece616's Avatar
Night Pic
The mode and fan speed buttons don't light up on mine, and for some reason the "TEMP" button is much brighter than the rest, but it's still better than stock.
(they light up bright white in person, not slightly blue as the appear)
Old Jul 7, 2008 | 05:40 AM
Kevlo911's Avatar
Kevlo for President
You need to sand the LEDS so you don't have hot spots. I had originally did that but I had to ditch the idea since it wasn't bright enough. Now I have 2 leds per hole lol. And they are 5mm leds, it was a ***** to made it fit.
Old Jul 7, 2008 | 05:55 AM
Zshopa's Avatar
nice clean job, yea i agree with Kevlo911 definitely sand your led's it will make a much smoother light... no hot spots or get some wider angle LED's i used the ones with the flat ends and it looks real nice
Old Jul 7, 2008 | 07:28 AM
Reece616's Avatar
I have some brighter 5mm white leds coming in soon so maybe ill redo it and sand them a little. For now it's good tho. I'm working on putting some leds in the ring that goes around the ignition but it's tough.
Old Jul 7, 2008 | 08:00 AM
BLACKonBLACK98's Avatar
Former Vendor
or:
i did this a while ago and then just bought the "neo wedge" replacments.
the reason the temp is brighter is because it has its own little pod which confines all the light.
Old Jul 7, 2008 | 08:16 AM
maximase86's Avatar
I love lamp.
Nice work reece!
S
Old Jul 7, 2008 | 09:15 AM
Reece616's Avatar
Originally Posted by BLACKonBLACK98
or:
Yea, those would work too haha
Also, pieces behind the other buttons aren't as clear as the pieces behind the temp buttons, so that doesn't help much either.
Old Jul 7, 2008 | 12:30 PM
Kevlo911's Avatar
Kevlo for President
Mine look like that, but a bit brighter now.
Old Jul 16, 2008 | 09:13 PM
matrix11229's Avatar
or:
Do you have a pic of your climate control ?
Which type of bulb did you buy and what color ? There are lots of them :
Is it type A ( 8mm) ?
http://autolumination.com/74.htm
Could these bulbs fit ?
http://cgi.ebay.com/ebaymotors/_Car-...3756.m14.l1318
Old Jul 17, 2008 | 07:04 AM
Former Vendor
i don't remember but measuring is a pretty basic skill. i haven't put anything back in my car so the gauge cluster is the only pic i have.
Old Jul 17, 2008 | 09:39 AM
Looks nice man
What led colors did you use ?
I want to have blue illumination like on my Premier mp3 screen:
Would UV color mixed with the climate control green panel produce blue ?
What brightness leds should I buy if I need to sand them ?
Old Jul 17, 2008 | 01:52 PM
Kevlo911's Avatar
Kevlo for President
I used white leds and red leds.
I would get at least 5000mcd leds
Old Jul 28, 2008 | 01:13 PM
ohaple's Avatar
so I found those bulbs on autolumination, and was considering it, but does it really look good, or does it look half ***?
Old Jul 29, 2008 | 12:36 AM
t65k3's Avatar
Still Learning
Very nice, no more messy wires......
I used white with 20000mcd. I did sand them......
Old Jul 29, 2008 | 05:29 AM
Reece616's Avatar
yea, the other setup didn't make sense to me, so i decided to do it my own way, and post it up for the org to see and try for themselves.
I dont remember what the mcd was for the leds i used but they're bright enough
Old Jul 29, 2008 | 08:01 AM
ohaple's Avatar
do those neo wedge replacements have the resistor built in, or you you sitll have to wire one up
Old Jul 29, 2008 | 08:26 AM
Reece616's Avatar
i havent used them, but im assuming since they're replacements, that you wont need resistors.
Old Jul 29, 2008 | 08:46 AM
ohaple's Avatar
ok thanks
Old Jul 29, 2008 | 08:50 AM
Former Vendor
they have a resistor and a reverse voltage diode built in iirc.
mikeg75
Nov 30, 2015 05:12 PM
EdRomo86
Sep 12, 2015 07:49 PM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
