Trying to install warpspeed B-pipe, rusted nut?
One of the nuts that hold my B-pipe onto the cat is completely rusted and appears to be rounded. Does anyone know of what I can do to fix this and get it off? I took it to an exhaust shop and they wanted "60 dollars, possibly more" to get this off.
One thing I am unsure of, I can't really tell, is it a bolt that slides through from the flange on the cat, or is it a stud? If it was a bolt I guess I could go to town with a grinder and get a new one, but what do I do if it is just a stud?
Ok, I have never done either before, I assume with drilling I just take a drill bit and punch it through from the catalytic converter side of the flange?
Then what, do I need to get a new stud and thread it or can I just stick a bolt through and screw a nut on?
Ok, I got underneath, I guess there is a small pipe where the rear o2 sensor is, I was trying to remove the wrong nuts.
I refocused my efforts to the flange directly on the cat.
These 14mm bolts are facing toward the cat (the head of the bolt toward the rear of the car) and there is no nut on the other side of the bolt, it looks like it screws right into the catalytic converter flange.
So far, no luck cracking them. I have a problem though, with the other pipe and the resonator there, it isn't possible to drill straight in. How should I do this?
Your most likely going to have to cut your stock b-pipe off. So cut it at a few places.
1. In front of the resonator.
2. Right before the bend around the axle before the muffler.
Those bolts will be rusted aswell. Did you buy a muffler too? or are you using the stock exhaust?
Ok, one of the bolts sheared off and the other broke free. The B pipe is now freed from the cat, which will allow me to drill part of that bolt out.
Now, I have been completely stopped dead in my tracks by the rear o2 sensor. I honest to god can not crack this loose. I have been soaking it with penetrating oil and no luck.
I have an oxygen sensor socket, but my problem is, with the b-pipe attached to the cat, I can't get this o2 sensor socket and wrench on and have any leverage. With it off, the whole pipe is moving and twisting and I can't get any force on it at all.
It would be great if I could just unplug the o2 sensor and just take the whole B-pipe off and work on it out of the car, but I undid that little rubber thingy and it is just wire, there is no connector up there.
I can't believe it...I have gotten so far and I am halted in my tracks by a flippin o2 sensor......
Anyone ever seen a grown man break down into tears on his driveway?
ok nvm on the 02 sensor, I figured there HAD to be a plug in there somewhere so I just yanked on the wires really hard and sure enough the connector came out.
Ok here is the problem now, how do I get the back of the B-pipe around the rear beam? I've tried angling it every which way. My car is on jackstands, it looks like its a piece of cake on a lift, but I dont have one available. Any ideas anyone?
It is the stock exhaust, I unbolted the muffler, so now it is just that section of stock pipe that goes from the cat to the muffler.
Yep, ive got that removed. My only problem is that it is hanging up on the rear beam axle. The flange is either scraping up against the beam or my brake lines, and the top of the pipe where it goes to curve downward again is always hitting the fuel tank.
No matter which way I turn or twist it, I cant get the pipe to clear the rear beam or the fuel tank. I know there has to be a way to get this out without having to sawzall the pipe in half....
Ok, I was overthinking it trying to angle it every which way. I just moved it straight forward and got it off lol.
On a sidenote, my cheap *** "Powerbuilt" jack just exploded and sent my car smashing straight to the ground. I think I am going to take a break from my exhaust work for the time being lol.
When warm liquid sprayed all over my face I was like "oh god...some body part of mine just got smashed under that" it was just jack oil, but dang it scared the crap out of me.
Oh my god....this project is getting worse and worse..... Here is another update.
1.) My oxygen sensor on the old B-pipe is seized on, my socket just rounded the threads. How the **** does something get rusted on so well? I have been soaking the damn thing in penetrating oil for 2 days now off and on, ive been tapping on it with a chisel and hammer to try and crack some of the rust loose, I've tried heating up the bung with a torch, I can't flippin believe this.
2.) The stud that I have to drill out...well even with a metal drill bit the surface of the sheared bolt is smoother than silk, the damn drill bit wont even bite!!!!!!!!!!!!! Not to mention it is underneath the car at a ridiculous angle. Does anyone have any idea how I am supposed to drill this out or get my o2 sensor off?
Honest to god, at this point I am scared ****less to try and attempt the y-pipe. I have done exhausts before, on cars older and with more miles than this Maxima....NEVER have I run into trouble like this. Unflippinbelievable.......
lowpost99
05-16-2021 11:18 AM
MaxLife17
06-27-2019 01:37 PM
-ReLLiK-
09-08-2015 12:02 PM
sdotcarter
09-02-2015 09:53 PM
