HELP PDQ
Old Jul 16, 2008 | 05:18 PM
tigersharkdude's Avatar
HELP PDQ
check it, cars been acting super gay. misfiring when sittin still. go get it checked, they tell me that cylinder 3 is misfiring. any help on what this could be. i think its a coilpack from what ive heard from other ORGer's
Old Jul 16, 2008 | 05:25 PM
kzoosho's Avatar
What year is your car?
Old Jul 16, 2008 | 05:27 PM
S14-NEO's Avatar
+1, iirc there is a TSB on coil packs and also a EGI harness (but the harness mainly cause MIL lights to pop on.
Old Jul 16, 2008 | 07:06 PM
So, I trust you have a CEL?? Well, whoever checked your car should have told you the code number in addition to saying cylinder #3 is misfiring. Then you can confirm the code number with the info given in the Haynes/FSM etc. Simple detective work.
You do know how to check the codes yourself for free, right?
Do you have a FSM or Haynes at your disposal?
Do you have a multimeter to check the coilpacks with?
Old Jul 16, 2008 | 07:21 PM
internetautomar's Avatar
mod or sell?
swap the coil to another cylinder and see if the misfire follows it.
if it does, you have a bad coil
if not check the spark plug and the fuel injector.
Old Jul 18, 2008 | 05:32 PM
i was almost positive it was the coil, went and got one and man what a diff. thanks for the help
Old Jul 18, 2008 | 05:42 PM
Jamaha80
Did you have the chance to see any fire blow out your tail pipe during the misfire(s)??? Thats THE BEST! Nothin like dumping raw fuel on down a pipe heated to 500+ degrees!
Old Jul 18, 2008 | 07:09 PM
i could never check it was to sparatic[?]
black_maxed95
Oct 6, 2006 11:52 PM
Spaniard
24
Mar 11, 2004 07:31 PM
Gamezilla
Feb 15, 2002 06:52 PM
Gamezilla
25
Dec 24, 2001 09:43 AM
