womp, womp, womp?
Old Jul 24, 2008 | 05:39 PM
sparky1562's Avatar
womp, womp, womp?
I have been hearing this sound for a while now. A low frequency womp, womp, womp sound. Gets worse when turning, have not noticed if right or left is worse.
I have been through the brakes (new pads, rotors, greased pin), no change.
replaced driver axle (second torn boot), new boots on passenger last fall, no change.
Put the tires off the 08 Max on it, no change.
Nothing loose that I can tell.
Read the stickies about wheel bearings. Is that it? If so, how do I confirm and tell which side?
Old Jul 25, 2008 | 07:38 AM
maximabebe's Avatar
Is your sound consistent with vehicle speed and wheel rotation? Meaning - the faster you're traveling, the more pronounced your vibration becomes? If so, I would say yes, its the wheel bearings. Jack up the front of the car, wiggle the wheel up and down and side to side with the tire still on. Should be little play but nothing worth writing home about. If you have significant play or looseness, then I would narrow it down to that one wheel and have the bearing replaced. Personally, I would buy new wheel bearings for both sides, then remove the whole hub assembly, take it to a shop with the new part and have it hydraulically pressed in. Labor using this method shouldn't cost you more than $30 or so per side. Good luck.
Old Jul 25, 2008 | 07:54 AM
MaxFanatik's Avatar
i got the same ISSUE around left turns killer sound esepcially when the car stands for a few hrs !!! had axle replaced numerous times, had my all my ball joints tie rods checked seems good. i also get whomp whomp sound at 50-65 and on low speeds a hard liek clanging smetimes
Old Jul 25, 2008 | 07:59 AM
bigpulve+'s Avatar
wheel bearing.
Old Jul 25, 2008 | 10:03 AM
sonicrunch's Avatar
I've had the same problem for 2.5 years now. I'm not fixing it until I have to.
Old Jul 25, 2008 | 11:10 AM
bigpulve+'s Avatar
I have had it since 06.........its not making it dangerous to drive so I dont feel like paying 400 bucks to fix it.
Old Jul 25, 2008 | 03:22 PM
KiNgJaMEs's Avatar
i just got the same noise lately after i installed matt's BBK HELP just had the wheel bearing yesterday and its still there. other people can hear it. if anyone has an answer for me PM me asap
Old Jul 25, 2008 | 03:45 PM
sparky1562's Avatar
Mine seems to be more noticeable turning left, but it is there turning right as well. Increases with speed. I jacked it up and tried to move each wheel and there is no play that I can tell. All wheels roll freely. I guess I just live with it like others said until it gets worse. When the bearing went out on my D-max it was obvious. 1/2 of play or so.
Old Jul 25, 2008 | 04:23 PM
leefitz's Avatar
I had this problem as well a few years back on my '97 Max and the shop I go to said it was my front strut plates, had them replaced along with new struts and the problem was gone. I had the same sounds and vibrations and they were worse when turning. Not sure if there's a connection but thought I would throw this out there.
Old Jul 26, 2008 | 07:42 AM
sparky1562's Avatar
I plan on replacing the struts and the mounts in the next month or so. Well see if that solves it.
Old Aug 19, 2008 | 11:15 AM
mitchz's Avatar
check your wheel bearing. i had this on my 82 celica.
Old Aug 19, 2008 | 11:28 AM
j2b4osan's Avatar
It could possibly be the tranny. (this is if its really not a wheel bering which would totally be more likely) Ive only personally had experience with a similar sound being the tranny once and it wasnt a maxima it as a 91 accord. have it checked by a transmission specialist if its really loud and your sure its not the bearing
infinimax96
Feb 13, 2012 04:57 PM
charlestek
Sep 4, 2005 07:32 AM
sunten1
Aug 5, 2005 07:04 PM
perrymaxima
Sep 23, 2002 03:34 PM
rich1223
Jul 25, 2002 11:55 PM
