tire rotation jacking up car
Old Nov 6, 2001 | 04:11 PM
shane's Avatar
I need to rotate my tires soon and will do this myself,can i jack up one side at both places on the side of car where you jack it up at with two factory jacks,seems like it would be faster to rotate if i can do this thanks
Old Nov 6, 2001 | 04:33 PM
mlocke's Avatar
Re: tire rotation jacking up car
You mean with two scissor jacks? I've done that in the past but only with a much ligher vehicle. It's not safest thing to do (a job much better performed with two jackstands like I have now). Definitely wouldn't poke your head underneath while doing this.
Old Nov 6, 2001 | 04:42 PM
max808's Avatar
i've done that, it works ok. safer way is with jackstands.
Old Nov 6, 2001 | 04:44 PM
Mishmosh's Avatar
Don't use the crap jack that came with the car. Use a standard jack--you can use two at each "m" mark on the sides as you've mentioned or if you jack high enough on one "m" mark, you will find that the wheels to lift off the ground front/back so that only one jack is needed.
Old Nov 7, 2001 | 03:38 PM
shane's Avatar
I have a floor jack maybe another one around here also that is about 4 inches round at the part that picks the car up,can i use both of them and where can i put them at to jack the car up thanks
Old Nov 7, 2001 | 04:08 PM
Mishmosh's Avatar
Like I said, only one floor jack is needed to do one side. Use the dedicated jack points on the sides of the car. There is one under the drivers door and one under the passenger's door. There are two notches there that make it look like an "m". Check it out.
Old Nov 7, 2001 | 06:33 PM
BRIGBOY's Avatar
Ya one jack is plenty, use the front spot and lift untill the rear wheel is just off
but its helful to have a friend so you can swap the wheels at the same time. The car won't be under stress too long, only takes a minute.
Old Nov 8, 2001 | 07:09 AM
Jason96GLE's Avatar
Whenever I rotate my tires I do the following:
1) Jack the front of the car on the center sub frame rail that holds the engine/tranny in place.
2) Place a jack stand on the square shaped fram rail just behind the front tire.
3) Now jack up the rear of the car by placing the jack in the center of the rear axle.
4) Place a second jack stand under the rear square shaped frame rail.
Now you will have one side lifted for front to back rotation.
Old Nov 8, 2001 | 07:18 AM
ny96max's Avatar
why are we talking about this use your head and figure it out, ot else pay $10 and have it doen at a local mechanic or car repair shop!! GEEZ
Old Nov 8, 2001 | 07:27 AM
seven's Avatar
all you need is 1 jack: lift on the front jack point until both tires are off the
ground
Lakersallday24
Jun 16, 2019 01:35 AM
JMag90
Aug 25, 2015 09:17 AM
District
Aug 15, 2015 08:23 PM
