replacing starter solenoid
Old Aug 10, 2008 | 06:44 PM
Chris Kapinos's Avatar
LLAMA
my buddy is out of state from me, and he has minimal mechanical aptitude, but he described problem to me, and im about 90% sure its the solenoid, (he turns the key, it clicks once and nothing.. battery is good) i dont remember my vq30, is it easy enough to do? IE: reachable from above the car, or should i recommend he go to a mechanic?
Old Aug 10, 2008 | 06:55 PM
jstew's Avatar
The starter is pretty simple to remove. I took out the battery and airbox, then it's just 2 bolts holding the starter on. Took me 20 minutes.
I couldn't find the solenoid switch and the starter was pretty worn anyway so I ended up buying the entire starter instead of just the solenoid.
Old Aug 11, 2008 | 12:09 AM
Delvin's Avatar
Good luck finding just the solenoid cheaper than the whole unit reman'd. At least at my job the you can get a reman'd starter cheaper than just the solenoid itself. I dont think I've ever just sold a solenoid by itself for a starter that has one attached to it nor have I ever had to replace one on a started back in my wrenching days. Since remans are cheap now and offer good warranties its the most popular way to go now.
Old Aug 11, 2008 | 08:06 AM
JtzMax's Avatar
Whatchyou say?
$30 ... Autozone for the solinoide! FTW !!!!!
To get to it, it's not that hard. It's under the intake crap and it's only 2 - 10mm bolts holding it on. No need to remove the whole starter even. It's really a 5 min job. The stud nuts are 12mm and you just pull the Pos bat lead (off the bat) and off the solinoide, disconect the other wire and the 2 bolts ... slips right out. Do becarefull of the little rubber insulator (space holder) though ... it's easy to loose in the engine bay and then you spend an extra 10 min's looking for it. LOL
lowpost99
Oct 26, 2025 06:53 PM
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
TheMafia
Sep 4, 2015 08:26 AM
