P0500 and p0600, any ideas what to change first?
Old Aug 15, 2008 | 04:32 PM
DCZC's Avatar
I have replaced the ks ans bank 1 sensor 1 o2, I had tighened the cluster per the stickies to help the vss. My speedo and tack work fine any ideas?
Old Aug 15, 2008 | 06:34 PM
DCZC's Avatar
any help?
Old Aug 16, 2008 | 11:56 AM
90EightSE's Avatar
According to the 1998 FSM page.EC-4
P0500 [0104] Vehicle speed sen/circ
P0600 [0504] A/T Comm Line
p.EC-299
P0500 [0104] The almost 0 MPH signal from the vehicle speed sensor is entered to ECM even wen the vehicle is driving.
Check: Harness or connector (The vehicle speed sensor circuit is open or shorted)
Check: Vehicle speed sensor
p.EC-314
P0600 [0504] ECM receives incorrect voltage from TCM (Transmission Control Module) continuously.
Check: Harness or connectors (The circuit between ECM and TCM (Transmission Control Module) is open or shorted)
Check: TCM
Old Aug 16, 2008 | 01:15 PM
maf2003111's Avatar
it could be the speedo itself. maybe you can find a used one at the junkyard or ebay. Make sure to test the VSS 1st by using the Cruise Control for a while and see if it stays on. If the car shifts fine then i wouldnt worry about he TCM bc if it was bad the car would go into limp mode and not shift. I had the same problem not to long ago and its was the connections on the back of the speedo, but u said u tighten the screws so it might be the speedo.
*edit*
Almost forgot, might as well do the steps to get tranny codes if any http://forums.maxima.org/4th-generat...ere-first.html
remember the 1st long flash means the start of flashes so dont count that one
matts95max
Apr 23, 2025 10:44 AM
RWCreative
Sep 21, 2015 11:01 AM
toyoking
Sep 16, 2015 07:05 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
thenewguyy
Sep 12, 2015 11:12 AM
