LED turning lights
Old Aug 24, 2008 | 10:48 AM
Zamochy's Avatar
LED turning lights
i recently tired to plug in some led lights instead of my stock white blub, as i pluged the leds in i noticed that when i put on the turning signal the lights do not turn on... should i be using another type of led or what am i doing wrong?
Old Aug 24, 2008 | 01:48 PM
thedwyer00's Avatar
First of all, what exactly did you do? Did you just do a swap out of bulbs or did you try to rewire it?
Old Aug 25, 2008 | 07:41 AM
Zamochy's Avatar
just swap the bulbs
Old Aug 25, 2008 | 08:01 AM
Shoto925's Avatar
try taking the bulb out, turning it 180 and putting it in that way
Old Aug 27, 2008 | 11:49 AM
Zamochy's Avatar
i did that, when i plug the back ones in the only way they work is when i click the hazards, and only the back ones work...
Old Aug 27, 2008 | 11:53 AM
IlyaK's Avatar
The Golden One
You need a resistor I believe. Just get regular amber bulbs...leave the LED's to the lights that only turn on and off (not blinkers).
V-Leds on Ebay.
Old Aug 28, 2008 | 01:57 AM
kzoosho's Avatar
Um you may have blew your fuse also. If they work with the hazzards but not the signal you have blown a fuse. Also once you do get it going you will have a fast flash.
Old Aug 28, 2008 | 04:04 AM
maxprivate's Avatar
Black Lion
Kzoo he said he just swap the bulb, I dont think it will flash fast if you use the bulb holder. Mine flashed fast when I didn't use it for my led turns so I had to put a bulb in the socket and just tuck it out of the way . They do sell resistors that you can solder on the bulb holder to mimic the effects of a bulb in place.
tsi6001
Oct 3, 2022 10:23 PM
Sport
Jul 3, 2017 05:40 PM
spidgeon
Aug 18, 2015 05:46 AM
220k+ A32
Aug 17, 2015 03:57 PM
kirkhilles
Aug 8, 2015 10:53 AM
