Where to drill hole in firewall?
Old Aug 24, 2008 | 04:25 PM
wootwoot's Avatar
I have a 1999 maxima and am trying to wire up an amp but this is the first amp/sub install I have done. I am looking for a good place to drill a hole in the firewall but I am not sure where. Can someone post a picture showing me where you have drilled a hole? Thank you.
Old Aug 24, 2008 | 04:34 PM
papo020's Avatar
I personally NEVER drill a hole through the firewall! I don't like the idea of doing it. Just look on the firewall and look for rubber grommets (I think that's what they're called) that have wires running through it and use those. I ran mine through one about 2 1/2 feet away from the drivers side. Perfect size as long as ur not running huge gauge.
Old Aug 24, 2008 | 04:35 PM
mista0406's Avatar
Best way to go for running any wire is go through the harness gromet by the drivers side wheel well than to make a new hole.
Old Aug 24, 2008 | 04:52 PM
papo020's Avatar
Yea you can do that; but there are already holes in the firewall with wires running through it. Just use one of them so you don't have to drill anything. But if you want to drill go with Mistas idea.......
Old Aug 24, 2008 | 05:31 PM
CRiME's Avatar
oem ftw!
Don't drill if you don't have to. Check near the middle of your firewall to see if your 99 has this hole:
Not my picture, but my 95 had that same hole. I used it to run my amp wire and ground signal from my RPM switch to the 00VI. All I had to do was pop out the little rubber grommet/cap and then the rest was history!
Old Aug 24, 2008 | 06:04 PM
mista0406's Avatar
the way i was saying is where the main harness is you dont have to drill whatsoever and it keeps your wires away from the engine heat its right under the splash shield by the drivers side front tire.
Old Aug 24, 2008 | 06:44 PM
papo020's Avatar
Exactly the one I used! Best one IMO.
Oh ok. Misread your post. Gotcha now!
Old Aug 24, 2008 | 06:45 PM
phatryan69's Avatar
just start knockin on spots till you hear one that sounds hollow and you will find one thats how i did it
Old Aug 24, 2008 | 06:48 PM
papo020's Avatar
Waste of time....The ideas already presented are the best. You don't have to drill anymore holes. You already have existing holes in the firewall; why would you want to add more?
Old Aug 24, 2008 | 06:53 PM
WunMing's Avatar
There is a hole covered by a rubber plug in the middle area. I'm installing an amp as well and I didnt have to do any drilling to run the power cable into the interior. Now all thats left is hooking stuff up and crossing my fingers. My first time putting an amp and subs in btw.
Old Aug 24, 2008 | 06:56 PM
papo020's Avatar
^that's exactly the one that we're talking about! It's the best one. It's right there. Good luck with the install. It's very easy as long as you have a little knowledge. Make sure you run your rca cables on the opposite side of your others. A lot of people say it doesn't matter; but sometimes you'll get humming from them being together (in my experiences).
Old Aug 24, 2008 | 07:04 PM
CRiME's Avatar
oem ftw!
Not so sure if I'd follow the drill through hollow sounding spots advice. Then the poor guy might be back here a couple days later with a "HELP! BRAKES ARE SHOT" thread, like what recently happened to another member on here.
Try that existing hole in the center. If for some reason it doesn't work, you can look for the other one by the D/S wheel well.
Old Aug 24, 2008 | 07:35 PM
wootwoot's Avatar
On my 99 I have an indention for the hole in the picture but there is metal covering it. Is it ok to drill this still? Where will this hole enter the car? Would I be better off using the D/S wheel well? I can see where the wires go down the wheel well but I am not sure where they end up either.
Old Aug 24, 2008 | 07:39 PM
papo020's Avatar
You have metal covering up that hole? I've only seen rubber grommets. I'm not sure why it would have metal there so I wont give you an answer on that. But that hole leads below the dash on the drivers side. Look pretty much directly above the gas pedal. Is that metal piece screwed in or does it look welded on or anything like that?
100th post! woo-hoo!
Old Aug 24, 2008 | 08:16 PM
tigersharkdude's Avatar
if you wanna drill,i went through a small diamond shaped area on the drivers side.
look at the strut mount then look at the fire wall you should see what im talkin bout
Old Aug 24, 2008 | 08:22 PM
wootwoot's Avatar
It just looks like there is supposed to be a hole but a piece of sheetmetal is perfectly positioned behind the hole. I will try to take a picture of it tomorrow.
Old Aug 24, 2008 | 09:11 PM
travmaximas1998's Avatar
thats where i went
i can take some pics tomorrow and show u where mine is
Old Aug 24, 2008 | 09:44 PM
CMax03's Avatar
take a 1/4" tube or 5/16" tube insert the wire tip into the tube and push the tube thru an existing rubber grommet on the fire wall, and then simply pull your wire thru....
Old Aug 24, 2008 | 11:31 PM
wootwoot's Avatar
Originally Posted by travmaximas1998
thats where i went
If you could send a picture that would be great.
Old Aug 25, 2008 | 09:51 PM
i will get the pics up tomorrow
school internet is runnin too slow dangit
to many ppl on in the dorms
Old Aug 26, 2008 | 07:52 AM
Old Aug 26, 2008 | 09:46 AM
thanks for postin ur pics
mine would of been about the same lol
i went a little lower on the firewall, on the otherside of that shape
stupid photobucket isnt workin!
Old Sep 4, 2008 | 01:12 PM
criative's Avatar
That's where I drilled mine this past weekend too
Old Sep 4, 2008 | 02:05 PM
pmohr's Avatar
No more Maximas...
That spot works just fine...if you have an automatic.
sliptap
Sep 30, 2015 05:57 AM
uttadms31
Sep 30, 2015 05:24 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Socalstillen
Sep 26, 2015 12:01 PM
