What temp is your motor?
Old Aug 28, 2008 | 08:08 PM
Scottyboi's Avatar
I installed the autometer water temp gauge. What i did was just disconnect the stock water temp sender and just connect the aftermarket one to there, since my stock one didnt work. My question is..did i stop anything else from working properly by doing this?
My temp is always at 230, is this a little high? When i stop at a light for a while it increases purdy quick...since it is about 105 around here and i am boosted.
Anything i can do to help lower this? I already ordered hood spacers to help vent the heat.
Old Aug 28, 2008 | 08:18 PM
vqmaxman's Avatar
I'd get an tranny cooler If your an auto and I am sure you have an oil cooler because your boosted. I would go with the hoodscopes.
Old Aug 28, 2008 | 08:42 PM
vqmaxman's Avatar
The normal temp readings are from 205-210 but anything abit over Is okay and If your in the 225 or over that's not normal.
Old Aug 28, 2008 | 09:06 PM
maximase86's Avatar
I love lamp.
Are your fans working properly? If so, are they moving enough air? I wonder if your intercooler is causing some flow problems for the radiator?
Are your fans controlled by the temp sensors? Have you considered rigging them up to a manual switch instead?
S
Old Aug 28, 2008 | 09:15 PM
Feldman's Avatar
I am pretty sure the fans are triggered by the temp sensor. Your fan should click on once the coolant temp gets to 205
AC off, engine temp <205 = No Fans
AC off, engine temp >205 = 1 Fan
AC on, engine temp <205 = 1 Fan
AC on, engine temp >205 = 2 Fans
I think this is all correct, hope it helps
Old Aug 29, 2008 | 12:50 AM
pmohr's Avatar
No more Maximas...
It also varies by speed.
Interesting that the Fed and Cali spec ECUs control the fans differently...
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
Apr 16, 2020 05:15 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
