sunroof question
Old Sep 6, 2008 | 08:20 PM
xkazik's Avatar
sunroof question.updated picture inside
Does the sunroof seal have a cut in the middle ? like a split between the seal ? its hard to explain , but my sunroof is leaking and its raining , when i looked at it i seen a split in the middle
http://i16.photobucket.com/albums/b1...ik/sunroof.jpg
is this normal or is that were my leak can be ? anyone can help .
Old Sep 7, 2008 | 05:58 AM
njmaxseltd's Avatar
huh?
pic?
replace the seal?
Old Sep 7, 2008 | 07:04 AM
internetautomar's Avatar
mod or sell?
yes there is a gap on the sunroof seal. it is where the 2 ends meet and it gets larger with age.
now I haven't had one leak into the car from there, it usually leaked because the sunroof wasn't flush with the roof.
hobomobo's Avatar
searching for leaking sunroof turns up lots of help
Old Sep 7, 2008 | 11:24 AM
xkazik's Avatar
My sunroof closes flush with the roof, but then when you [press on it a lil it goes down a bit , is that normal ? or do i need to fix something
Old Sep 7, 2008 | 11:33 AM
phatty99's Avatar
ttt
Old Sep 7, 2008 | 05:50 PM
S1cTech's Avatar
You need a new seal. And about the pushing down thing it is usually normal to push down a little, but not to the point of unsealing. You can fix that by putting on new shims or doing the sunroof rebuild kit posted in the stickies.
Old Sep 8, 2008 | 04:36 AM
nsnrider's Avatar
check your drain hoses to make sure they a clear or dirt and debree.
Old Sep 8, 2008 | 10:18 AM
Start here first. Easy and quick to do. A sunroof drain is located in the trunk under where the antennae and jack is...
When yo find the 'Y' connection, one hose is for the antennae drain, the other is for the sunroof drain.
Old Sep 8, 2008 | 10:25 AM
xkazik's Avatar
Im pretty sure my drainers are clean i pure water in all 4 of them and the water came out under the car.
bigdogsteve
Jan 31, 2018 04:18 PM
Fbana41
Aug 29, 2016 12:18 PM
Forge277
Jun 13, 2016 09:26 PM
Unclejunebug
Apr 2, 2016 05:42 AM
jonreidhead
Jan 6, 2016 09:38 AM
