My Left fog light burns out every 2-3 days why?
Old Sep 7, 2008 | 09:49 PM
enik23's Avatar
for some reason on my left side my fog light burns out every couple days i mean h3 light bulbs cost ab 20 bucks per pair so i dont rly like that... the fog light it self is new my car was in an acident and they had to change the fog light. also on that side of the cari dont have a splash shield the one thats suposed to protect all the wires from water but it hasnt rained here in a a few weeks. so any clue wtf is wrong with it ?
Old Sep 7, 2008 | 10:02 PM
rex3001's Avatar
wrong fuse being used?
Old Sep 7, 2008 | 10:10 PM
arrocha87's Avatar
a wire is stripped and touching the frame? or its pinched from the accident?
Old Sep 7, 2008 | 10:59 PM
Snypa's Avatar
High wattage bulbs.?
Old Sep 8, 2008 | 06:38 AM
IlyaK's Avatar
The Golden One
EBay bulb?
I had ebay bulbs and they lasted a week. I put my OEM ones back in and they worked for like 5 months (I got 6000k look-a-like halogen bulbs on ebay for looks, waste of money).
Old Sep 8, 2008 | 07:51 AM
enik23's Avatar
the bulbs were of e bay but i mean the right one is sitting strong its the left one that keeps burning out couple days its been a few months and the right one is working good i even changed both of em at once and its always the left that burns out
Old Sep 8, 2008 | 08:11 AM
ChubbieBoi's Avatar
i rather buy the bulb from autozone or somewhere else then ebay...
Old Sep 8, 2008 | 11:43 AM
S1cTech's Avatar
holy crap. SAME THING with me, and it is pissing me off. It sucks cause it makes me look like a noob with a fog out when I want them on. It is my right one tho that goes out after a few days. I have tried 3 bulbs same thing. I even blew a fuse before then checked the ground and it was fine. I got to the point were I just did not give a **** anymore and was like... There just crappy lens anyway the only way I would want them is if they were HIDs. I was thinking of buying an HID kit too, but I was affaird the same thing would happen so I didn't...
Old Sep 8, 2008 | 12:08 PM
AndrewR2442's Avatar
My passenger side fog light would go out every month. Eventually i settled that the light is either getting too much wattage or the wiring is shorted out. I haven't fixed it either.
Old Sep 8, 2008 | 01:06 PM
choray911's Avatar
The Crazy Azz Cracka
Sounds like a bad ground. When the ground is bad the amperage passing through the wire has a limited path. This excess energy gets dissipated as heat in the bulb hence the blowing. If memory serves, the ground to the passenger flight is low in the front grill near the light where it gets wet every time it rains. Often, this water causes rust and corrosion to build up between the grounding terminals. I went with higher wattage bulbs and had to rewire the headlights and fog lights with 10ga wire.
Another thing to check is to make sure there is no corrosion on the terminal that plugs into the lamp, and that the bulb is clean and has no oil from your hands from installation
Old Sep 8, 2008 | 03:06 PM
S1cTech's Avatar
^ so wait your saying there is another ground? hmm, I would liek pics of this to find it.
Old Sep 8, 2008 | 03:38 PM
BILLVQ30_SE's Avatar
atleast yours doesnt go out every single time you turn them on. thats what mine does, no clue why. :-(
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
