gettin in to gear issues
Old Sep 15, 2008 | 10:26 PM
JonBlz's Avatar
a.k.a. STuNtMAN
okay i know my tranny is not bad or anything like that but my clutch its like i have to step on it really hard to the floor so i can get it into first gear and i hate what do you think the problem is help me out i wanna fix this issue
Old Sep 15, 2008 | 10:33 PM
Problemchild1one's Avatar
i dunno im gettin the same thing bro and third gear is a Bi**H sometimes even u get into or out i dunno man, hit me up Jose so we can do that thing this weekend bro early if you up 2 it lol
Old Sep 15, 2008 | 11:16 PM
Feldman's Avatar
could be any number of problems.
Clutch pedal out of adjustment
low clutch fluid
air in the clutch line
could just be your first gear syncro on the way out.
if all your other gears go in nicely i would lean towards the last one
A little more info might help us such as was this an all of a sudden kind of thing or just gradual, and have you done any work in the area recently.
Old Sep 16, 2008 | 06:47 AM
dralucard's Avatar
i had the same problem. it turned out to be low fluid because of a leaking clutch line.
Old Sep 16, 2008 | 07:24 AM
Snypa's Avatar
it could be as simple as low fluids, but imma assume you checked that already.
Old Sep 16, 2008 | 10:01 AM
99BettySE's Avatar
I have a similar issue but I don't think it would be the same cause. Sometimes at a stop I have trouble getting the shifter into first or reverse; I have to really jam it sometimes. I hope it's nothing wrong and I'm not gonna end up breaking my shifter. Anyone know what I'm talking about?
Old Sep 16, 2008 | 01:14 PM
black_maxed95's Avatar
low clutch fluid
good post, exactly my thoughts on this. im leaning towards the synchro on its way out too.
this is normal, just let the clutch out and put it back in and it should shift into gear fine.
Old Sep 16, 2008 | 01:19 PM
Feldman's Avatar
the syncros on first and reverse take the biggest beating because in most cases you cant sync it yourself with your revs like you naturally do with every other gear.
Black_Maxed95 hit it right on the head when he said let your clutch out and try it again or you could let your car roll a little bit if you aren't on a flat surface
Old Sep 16, 2008 | 03:50 PM
JonBlz's Avatar
a.k.a. STuNtMAN
well my fluid is good and its a brand new clutch i put the clutch in when i did my motor swap it goes into 1st sometimes lovely but then the clutch pedal feels like **** i gotta hold my steering wheel and press that pedal hard so it can go in 1st and then when its in 1st it feels like it wants to stall even wit the pedal pressed all the way to the floor could it be my clutch pedal or the MC
Old Sep 16, 2008 | 11:46 PM
beez5spdmax's Avatar
yo i had the same problem with my max for like a month in a half checked the line for air
checked both master & slave cyclinder and still had the same problem. some days it would be fine. i had my trans rebuilt in jan of this year by jeff at maxium tuning he sucks he is very over rated. but thats a another story anyway. this labor day weekend my tranny blew up i put in 1st then 2sec and boom i heard an explosion when i stopped i looked and had trans fluid all over the street.when i had it towed to my mechanic and we put it on lift my transmission metal was cracked. so get that fixed a.s.a.p but hey i bought a l.s.d tranny with 81 thousand miles so hopefully no trans problems for a while. and yeah jeff u suck maxium tuning sucks!!!!!!!!!!!!!!!!!!!!!!
Old Sep 17, 2008 | 03:38 PM
JonBlz's Avatar
a.k.a. STuNtMAN
okay heres the update i changed my gear oil to amsoil GL-4 75W-90 and it feels great butter shifts but i still have to press the clutch pedal all the way down im going to buy a new clutch pedal and MC and take it from there because the pedal i have its to spongy and it wobbles lolz the pedal is only $61 bucks at the dealer so thats a good price ill keep everyone updated but plz if you have any more info to the outcome plz chime in
Old Sep 18, 2008 | 09:10 AM
JonBlz's Avatar
a.k.a. STuNtMAN
same problem still gonna change the MC and the clutch pedal and see whats up
Old Sep 18, 2008 | 09:22 AM
dgeesaman's Avatar
Maintenance Monster
Don't change the pedal. It's just a hunk of metal.
If anything add the clutch slave and clutch line to your list instead.
Old Sep 18, 2008 | 09:56 AM
Feldman's Avatar
no need to change the pedal, probably dont need to change the Mc either.
Start with bleeding the system and adjusting your pedal travel.
Unless you are leaking fluid out of them your slave and master cylinder are fine
Old Sep 18, 2008 | 10:05 AM
99BlackMaxMS's Avatar
Check your clutch line for kinks or bubbles. As said above, if you aren't leaking fluid, it probably is not your master and slave cylinders.
My friend's 300zx has this problem only when it gets hot out, because the 16 year old clutch line swells when it gets really hot. Are you running a SS clutch line? They are only like $25 dollars iirc.
Old Sep 18, 2008 | 06:48 PM
NR_MAX's Avatar
I think im having the same problem. Keep me posted, im gonna check out what you guys said and let you know what i find.
Old Sep 22, 2008 | 03:50 AM
JonBlz's Avatar
a.k.a. STuNtMAN
im still having the same issue today im leaving my car at my cuzins shop gonna change MC and slave and adjust the pedal this is getting me really mad i use my car everyday to come to work and i gotta be fighting with the shifter
Old Sep 23, 2008 | 03:46 AM
JonBlz's Avatar
a.k.a. STuNtMAN
well i changed the master & slave cylinder still having the same freaking problem gonna have to drop the tranny and check the pressure plate and all
Old Sep 26, 2008 | 09:26 PM
JonBlz's Avatar
a.k.a. STuNtMAN
update info-the problem turned out to be the fork in the tranny was bent fixed that and changed the MC and slave and the clutch pedal and fixed the bent fork and now my car shifts like heaven so soft and lovely its just great thanx everyone for helping me out
Old Sep 27, 2008 | 04:16 AM
dgeesaman's Avatar
Maintenance Monster
The fork that pushes the throwout bearing?
Old Sep 27, 2008 | 01:37 PM
JonBlz's Avatar
a.k.a. STuNtMAN
^^^yep that was my problem buddy it wasnt lining up with the pressure plate or anything
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
