replacing radiator...what else?
Old Sep 16, 2008 | 01:31 PM
Llfe's Avatar
i'm going to replace my radiator and the thermostat tomorrow...wat else should i change out while i'm doing the radiator?
can ne 1 let me know if it's difficult changing out the thermostat?
Old Sep 16, 2008 | 02:22 PM
Accord4tehloss!'s Avatar
Hoses. if they are the originals there more then likely old and brittle and if they crack your stranded.
Old Sep 16, 2008 | 02:24 PM
mtrai760's Avatar
'Trynna' is not a word
to the hoses. Might as well replace the cap as well. Thermostat is easy.
Old Sep 16, 2008 | 03:20 PM
roxcrawler's Avatar
You can keep the old hoses in the the trunk of your car as backups.
Old Sep 16, 2008 | 08:39 PM
turbolaw99's Avatar
How about a transmission oil cooler, easy to mount on the new radiator before it's installed.
Old Sep 17, 2008 | 03:03 AM
nupemaxima's Avatar
coolant temp sensor, hoses and cap. Clean out your reservoir as well.
Old Sep 17, 2008 | 05:03 AM
j2b4osan's Avatar
yea just do a full flush of the coolant change the hoses and thermo. Sensor is way easy and it will throw a code when it's bad so why not just wait till it dies. And if the new rad didn't come with a new cap get one. You might want to take this opportunity to check the whole area for corrosion and rust it is prone to rusting. I painted all the hardware an mounting points black to fight corrosion after removing all the rust in the area.
Old Sep 17, 2008 | 05:18 AM
GreenMtnMaxima's Avatar
Definitely hoses and coolant flush, as mentioned.
Also, not sure what it looks like beneath your hood, but when I changed my rad and cooling fans, I used the opportunity to (1) look for rust problems and (2) degrease/wipe/detail the front end of the bay.
It's much easier to access some of the hard-to-reach areas without those big clunky pieces in front...Can you tell I have fat hands?
Good luck with your project.
Old Sep 17, 2008 | 11:52 AM
Llfe's Avatar
thanks for the ideas...gonna look for corrosion and try and stop it...put in new hoses and clamps...i was wondering what the coolant temp sensor looked like?...i bought thermostat...is that the same?...or i bought the wrong part?
PH98I30
29
Feb 10, 2025 12:03 PM
captchaos
Mar 15, 2016 12:18 PM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
