intake question
Old Sep 27, 2008 | 09:04 PM
maxkid123's Avatar
intake question
okay i have a short ram intake with a k and n filter on it and when i step on the gas prob around 30 40 percent with the windows open i hear a loud like shhh and wistle sound coming from under the hood...im i the only one with this sound or?? do i have a intake leak or sumthing or is that just normal...its really loud and annoying
Old Sep 27, 2008 | 09:10 PM
CRiME's Avatar
oem ftw!
Mine whistled too when I had it, but it wasn't that bad. You have the 00VI too right? I think I read somewhere that if you removed the restrictor plate that's behind the TB in the IM, it can cause a bad whistle too.
Old Sep 27, 2008 | 09:19 PM
99BettySE's Avatar
I have the Stillen intake and I do hear a very slight whistle just when I step on the gas, but it's nothing compared to the PSHEW that I heard from the Autozone rice-cone I had on my old car. I heard those where just normal sounds from cone filters. I could be wrong though.
Old Sep 27, 2008 | 09:46 PM
maxkid123's Avatar
i have my restricter plate in...should i take it out?? is it better if its out?? and yeah this is like a loud shhhhhhh and wistle mmixed i think im mite have a leak sumwhere or sumthing but idk where
Old Sep 27, 2008 | 09:51 PM
CRiME's Avatar
oem ftw!
Take it out & see if it changes at all. It's worth a shot if the noise is really bothering you.
Old Sep 27, 2008 | 09:57 PM
Snypa's Avatar
The whistle is normal, almost everyone has that, but im not sure about the pshhhh....might be a leak.
Old Sep 27, 2008 | 10:41 PM
Nismo's Avatar
Its the midpipe that makes the whistle not the filter.
Old Sep 28, 2008 | 09:28 AM
djluski's Avatar
whistling sound
mine whistles too. its b/c you probably removed the mixing box when you put in the intake. its normal and non threatening to the car. where is the restrictor plate behind the throttle body?
Old Sep 28, 2008 | 09:54 AM
dkillahster's Avatar
but doesn't any kind of leak after the MAF Sensor make the car dump wrong amount of gas??
my maf is in the front after the cone.. i took everything out... i still hear a phssss sound.. but only because of a hole that is partially plugged up.. iono what that is suppose to hook up to.
can anyone help me?
Old Sep 28, 2008 | 10:20 AM
Bandits50's Avatar
I just did the Stillen Hi flow intake as well and mine has the SHH sound as well when I get on the gas. Mine does not whistle. I to would think if you get the whistle it would be an air leak.
The one thing I thought strange was the Stillen instructions talked about the 2 parts to the air intake box and that their Hi flow system would replace that. However the Air collector that is attached to the frame near the radiator with two push pins and the condensation box at the bottom of the bent tube that would go into the bottom piece of the air intake box was not mentioned to be removed. I took them out and just relocated my boost sensor that was just attached the Air collector piece.
Is everyone else doing this as well or not?
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
