Bose is dead. Fix it or replace it?
Old Oct 10, 2008 | 11:06 AM
  #41
Bakermax's Avatar
I can't post a pic here, pm me your email address and I'm email you a pic. As for the adapter, the adapters are vehicle make specific, if I remember correctly, you just plug in the adapter to the stock harness and connect the right colors to the wires on the HU. I did get an alternator buzz so I put a power filter on and that helped. Then I replaced the front spakers, but the rear deck is still bose. I would recommend just replacing the stock speakers too.
Now on my 5th gen I replaced the bose with an alpine double din, I found the adapter at walmart believe it or not. All of the wires are colored the same as the wiring harness in the vehicle, just like the harness adapter from the 4th gen. I connected the walmart adapter to the stock adapter and connected all of the wires and that's it. Then I put a switch on so I could play dvd's while driving. I also replaced all of the speakers and pulled the bose sub. Now I'm going to get a sub.
Old Oct 10, 2008 | 07:55 PM
  #42
maximomo's Avatar
I fixed my 95 Bose using the steps on: http://madchef.5u.com/maxima/bose/fixes.html
and this worked just fine.
If you can't get yours fixed PM me and I'd be happy to work something out with you to fix yours.
Old Oct 12, 2008 | 08:10 AM
  #43
maxfever1987's Avatar
i would replace since some aftermarket ones give u a choice of control ur subwoofer if u have one thATS wat i did
Old Oct 12, 2008 | 08:27 AM
  #44
riceyasian86's Avatar
Replace it. Choose which features you get to have on your own HU. Be it MP3, CD-R, CD-RW, iPod hook up, XM radio, etc
If your Bose on an outdated system has died then I think it's time to fancy things up
My $.01
Old Oct 17, 2008 | 07:51 PM
  #45
jaywills1020's Avatar
Originally Posted by maxprivate
you should get a transfer here in j.c. nj firefighters top off At over 95,000 after just 7 years. that doesn't even include promtions. then you can get any system you want.
if i could catch the work there that i catch in nyc id do it in a heartbeat................then again its jersey.
melteye
May 16, 2016 12:02 AM
Balkins
Feb 1, 2016 12:45 AM
CreativeSkillz
Aug 26, 2015 04:23 PM
Maxinesdaddy
Aug 21, 2015 11:43 PM
kirkhilles
Aug 8, 2015 10:53 AM
