maf question!!
Old Oct 3, 2008 | 12:10 PM
bcmaxima96's Avatar
maf question!!
whats ups guys. I need to know if theres any way to test the mass air flow sensor to see if its working properly. my cars been having some running problems and I think it has to do with my maf but idk how to see if I'm right without having to go out and buy a new sensor. Can anyone help????
Old Oct 3, 2008 | 12:13 PM
njmaxseltd's Avatar
Symptoms? Describe "running problems"?
Old Oct 3, 2008 | 12:18 PM
Feldman's Avatar
i am sure if you search you will find the info you are looking for. I am sure it has something to do with hooking up a multimeter and checking the resistance though
Old Oct 3, 2008 | 12:58 PM
hot_wax_tree's Avatar
1. tell us what has been happening
2.search for it
Old Oct 3, 2008 | 06:55 PM
max ride 41's Avatar
what they said, and throttle body clean out probably needs it. but that of-course is a guess as im not mentok the mind taker......
Old Oct 3, 2008 | 08:17 PM
bcmaxima96's Avatar
alright well symptoms are an uneven idol from a high idol to a low idol , when i hit the gas pedal theres a delay before the car will rev sometimes sunds like its bogging out. While driving the car will jump because the throttle will just guive out on me and the engine has nothin. i had a vacuum leak in my intake which i fixed and it was much worse prior to the leak , also on occasion the car will stall..
Old Oct 3, 2008 | 08:26 PM
damn, scan for codes and your probably going to need a tune-up. how are your fluids, and the maf is an easy clean out, you just spray crc on the maf itself. there's a write-up in the stickies for probably all of this. look around.
Old Oct 4, 2008 | 02:33 AM
bcmaxima96's Avatar
the only codes that come up are for the intake air temp sensor which has always come up from the cai i has installed. also a code for an oxygen sensor i have to change. how much for a full tune up?
Old Oct 4, 2008 | 05:01 AM
njmaxseltd's Avatar
Originally Posted by bcmaxima96
codes are intake air temp sensor which come up from the cai i installed.
You should not have that code, did you plug the sensor back in? A CAI doesn't cause that code. Relocate the sensor and make sure it's plugged in.
Have that replaced.
Neither of those items will cause running symptons as you described.
Do check:
MAF
COILS
ECTS
TPS
Fuel Pressure
Old Oct 5, 2008 | 11:05 AM
bcmaxima96's Avatar
ects? and i am going to check the tps , how can i go about checking fuel pressure and the maf?
Old Oct 5, 2008 | 11:40 AM
nhaven's Avatar
ects = engine coolant temperature sensor
TallTom
57
Oct 14, 2025 05:16 PM
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
sliptap
Sep 30, 2015 05:57 AM
Socalstillen
Sep 26, 2015 12:01 PM
