p0443
Old Oct 17, 2008 | 09:45 AM
maxfever1987's Avatar
p0443
i have 1 code on my car
A)P0443 which is EVAP PURGE CONTROL VALVE
can anyone tell me where is this thing located is it the valve with a 6 pin connector with 2 hoses or the little black round thing ? thanks in advance
and wat is the EVAP PURGE VOLUME CONTROL VALVE?
Old Oct 17, 2008 | 10:12 AM
97-4DSC's Avatar
the evap box is in the left rear of the car opposite from your muffler its under the car so your going to have to lift the car or get down to see it
Old Oct 17, 2008 | 10:38 AM
djipka's Avatar
the code is very well explained in the sticky. also look at my threads and there is one that has the diagram of the whole evap system.
USE SEARCH!!!
Old Oct 17, 2008 | 10:48 AM
my question is that am i looking to replace the big 6 connector thing, the small balck round thing or the valve connected to the evap canister near the left rear tire
Old Apr 29, 2010 | 03:18 PM
nopepeno's Avatar
Hello guys, I think that I did something very foolish; I pooled the manifolds robber gasket and put it back on covered with general grease.
Some time ago when I replaced the rear injectors I damage my manifold screw's threads (the ones that attach the little cooper tube in the manifold’s back) so I was getting a nasty odor in my car while driving; I finally decided to fix the problem and replace the manifold, so I did; but now the car wont turn over (my car is a 1995 Maxima)
I crank the engine but nothing.
Maybe I damaged my cables?
Or the gasket is not doing a good seal…. I used also a bran new one but it slice over and it won’t turn over either.
Or I broke some kind of something electrical that wont let my car go on (I had to stop half way to turn the key to the on position to bring the windows up as it started to rain very hard.
(Note: I have gas half tank)
(I have battery juice)
All I get is code P0443
what do I do? any Ideas?
Ok I solved the problem, a 10amp fuse blow up from the fuse compartment located next to the battery, I replace it and my nightmare was over; the car started, what a relieve. I cleared the codes and I still got an engine light on after a short while. tomorrow I will check if the code still is P0443
I still got the same code so I replaced the top little plastic thing and the little Vacuum device too (these parts are on top of the manifold--valve evap.can.purge vol.sol and valve assy-control--) my problem is solved., you might get away by replacing only the valve evap.can.purge vol.sol==black plastic thing with 3 hoses entries==
bryants95max
Oct 2, 2015 12:52 PM
mkbruin
Feb 14, 2013 08:46 AM
jas1203
Jun 15, 2011 12:44 PM
Qbridg3
Oct 12, 2007 11:00 PM
mikemike
Apr 5, 2006 09:30 PM
