for maxima 's that are lowered and have a bodykit
Does you car hit bottom over speed bumps and pulling out of business parking lots. I plan ot get a bodykit and i plan to buy sprint springs. will my car hit bottom a lot?
thanks Brandon
thanks Brandon
![](https://maxima.org/forums/images/smilies/support.gif)
Re: for maxima 's that are lowered and have a bodykit
If you go straight down, yes. If you go sideway, you can clear them all.
thanks Brandon
thanks Brandon
Originally posted by carnal_c30
there will be those dips where you will scratch your car no matter what you do... be prepared to hear it scrape once in awhile
![bawling](https://maxima.org/forums/images/smilies/bawling.gif)
I had the Stillen front lip before I switched over to Sarona bodykit. I had very little problems with the Stillen lip, scratched it 3 times tops. With the Sarona, it's slightly longer/lower up front. I had a miserable time with it the first two weeks
![shiner](https://maxima.org/forums/images/smilies/shiner.gif)
SLOWLY approach any curb sideways like Tony said almost at a 45 degree angle (if cars behind you aren't honking by then) and you'll be fine. You shouldn't have problems with speed bumps.
yea, as Maxgurl pointed out, it also depends what kind of kit you have. Not just on the size/length of the lip, but the material/quality it is built from. The Stillen lip is made out of more flexible, durable material, it can take hitting stuff, while something like the Sorona is prone to cracking easily. So you gotta be extra careful!
soon2ownmax
08-13-2015 02:19 PM
laparka66
08-06-2015 09:36 AM
