Overheating and no warm air
Old Nov 20, 2008 | 01:03 PM
thinfine's Avatar
I have two issues. The first one is that my car is overheating. No smoke or smells, just a high temp on the gauge. The second one is that my heat isn't blowing warm air. I'm having to fill up with radiator fluid every 4 to 5 months. I don't drive my car very often but I don't see any leaks on the ground around the car. Any ideas? Thanks.
Old Nov 20, 2008 | 01:10 PM
kzoosho's Avatar
Check your fluid level. Thats a sign of low coolant.
Old Nov 20, 2008 | 01:14 PM
KRRZ350's Avatar
Also, best way to find where that fluid is going is pressurising the system, IIRC autozone loans the tool, but you need an adaptor to fit the smaller radiator cap on your car. The weep hole for a leaky water-ump housing o-rig is behind the crank-pulley, common place for it to disappear from while being very hard to pin point.
Old Nov 20, 2008 | 02:03 PM
Thanatos's Avatar
You have an air lock in the line. Let it cool. Remove cap and fill. With cap removed run engine untill fluid level lowers due to thermostat opening. Continue to fill until full. Replace cap and have a good day.
Old Nov 20, 2008 | 02:10 PM
thinfine's Avatar
Thanks to everyone for the prompt responses. This one does sound like a match though because it only let me put in a little bit of fluid before it was full. After I put in some fluid, it warmed right up. I guess it's about time to give the ol' girl a rest. Any input on that new Maxima?
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
