HELP AXLE HELP
Old Dec 27, 2008 | 08:15 AM
  #41
KiNgJaMEs's Avatar
I missed informed on the code i was getting sorry im getting code 1336 so whats that??
Old Dec 27, 2008 | 08:31 AM
  #42
pmohr's Avatar
No more Maximas...
http://boredmder.com/ecucodes/index....1995&DTC=P1336
You might've damaged the timing ring on the flexplate on removal or installation, or the CKPS is damaged/disconnected/misaligned, etc.
Old Dec 27, 2008 | 01:05 PM
  #43
KiNgJaMEs's Avatar
Update: Back to Square ****** F**in 1 she snapped again. HELP i need a longer axle any suggestions???
Old Dec 27, 2008 | 03:18 PM
  #44
pmohr's Avatar
No more Maximas...
At the same exact place? Can you take a pic of your axle with a measuring tape, measure it from the base of the shaft (where it meets the large CV joint cup) to the end?
Old Dec 27, 2008 | 03:54 PM
  #45
KiNgJaMEs's Avatar
will do when i pull it.
Old Dec 27, 2008 | 06:50 PM
  #46
MaximaSpd85's Avatar
i have a question, since youve been buying new axles, would the abs ring have anything to do with anything? like if you dont remove it even though you dont have abs?
Old Dec 27, 2008 | 06:52 PM
  #47
pmohr's Avatar
No more Maximas...
No, doesn't change anything regardless of the car being equipped with ABS or not. Only difference is the reluctor ring on the hub side of the axle, otherwise it's just an empty space.
Old Dec 27, 2008 | 08:18 PM
  #48
S1cTech's Avatar
you should just get a new Trani man. This sucks to happen and scares me a little because I just got my Axles done not to long ago. I even stopped racing because I am scared ****less for something to happen like this. Also the Drop prob did not help too much on the axles as they does cause strain on them. It could of been a faulty part but it hardly makes sense to happen on the highway in an auto because there is not a lot of load on the axles when your going the speed in an auto.
So it could be bad installation or the axle popped out of its race/cage and you kept driving it without knowing or it was not seated to begin with. Is your knunkle a little more out then normal from the suspension change? (Eventho that is not possible but maybe it could happen if your **** is bent) Have you done a good full aligment on the car after the suspenstion and axle change?
Either way you look at it. I would give hell down at who ever installed it. I would never EVER have an autoparts store install my ****. They are just kids learning there. Get it done by a real shop next time or someone you can trust that has a good rep.
Old Dec 28, 2008 | 03:27 PM
  #49
KiNgJaMEs's Avatar
Not too much time today it rained alot and i was able to pull the axle before dark.
refer to post 1 for the firsts axles condition
Here is the second axles condition
this is the first axles end that was severed off pay attention to the lines it (it looks to have been twisted off.)
Old Dec 28, 2008 | 03:33 PM
  #50
pmohr's Avatar
No more Maximas...
Can you throw an axle in and take a pic of how it sets in relation to the trans? Specifically directly where it enters the diff, how much space is there.
Seeing it like that and taking a look at the spare diff I have sitting here, it look as if when you're putting the axles in, you're just feeling the first click (when it slides past the frame of the diff, directly above the splines) and not slamming it home to lock the circlip beyond the splines.
The circlip is apparently keeping it secure just enough for the axle not to pop completely out, but it's moving back and forth, just enough for the splines to disengage. When this happens and the car is in gear at any speed, the splines in the diff start to round off the splines on the axle. That also explains how the first axle came apart, as there should be no torque on the axle splines past the circlip.
I'll upload pics in a few of what I'm talking about exactly.
Old Dec 28, 2008 | 03:40 PM
  #51
KiNgJaMEs's Avatar
ight when i installed the axle i pushed until i couldnt anymore and im not a lil guy. but i do see what your saying. what type axles are proven to work?? and what auto parts store do you use?? this is a New G&S axle from advance it seems to be alot bigger then the past one from advance.
Old Dec 28, 2008 | 03:52 PM
  #52
pmohr's Avatar
No more Maximas...
Most likely you were pushing, but the splines weren't lined up; you were just pushing the axle against the diff, but not into it.
Here's what I think is going on.
When you're installing the axles, it's coming out like this:
Obviously not seated fully, but unless you're underneath looking at it, you would never really know (that's why you always double check before dropping the car to finish up).
It should look like this:
That is fully seated (obviously it looks different if the trans housing is in place, but same exact principle).
Spot the difference?
Old Dec 28, 2008 | 04:00 PM
  #53
KiNgJaMEs's Avatar
gotcha. the first axle lasted for months, and the second lasted for about 30 miles. is it possible for the axle to slide out ?? i hope that made sense. do i have to alter the retaining clip before installation??
is there a thread on what axles people use mostly
Im lowered on Eibach, Agx KYB struts, BBK, with 5/8" spacers and on 20" wheels can any of that be a factor on why this is happening??
But dont get me wrong your making sense im just full of questions. thanks for the help
Old Dec 28, 2008 | 04:04 PM
  #54
pmohr's Avatar
No more Maximas...
It's possible that it slipped out on it's own, but also extremely unlikely; that circlip keeps the axle in there pretty tightly.
The circlip shouldn't need any modifications at all.
There's not that much choice for the A32, you've got OEM, raxles, or generic auto parts stores. They should all hold up just fine.
It's either an installation or trans problem.
Old Dec 29, 2008 | 08:09 AM
  #55
KiNgJaMEs's Avatar
does anyone have a picture of the axle installed in the car so i can see how it should look when seated to the diff?? You can even take a picture looking straight down through the motor if you have an after market intake.
Old Dec 29, 2008 | 08:36 AM
  #56
pmohr's Avatar
No more Maximas...
Basically you should only see the rusted and weathered metal from my pics above. There should be very little space between the large portion of the end of the CV joint cup and the housing of the trans.
If you throw one in and take a pic, it's easy to point out whether or not it's in properly.
Old Dec 29, 2008 | 08:53 AM
  #57
KiNgJaMEs's Avatar
thanks pmohr after a lil more research after the last post i seen where someone had to remove there strut to get a straight shot into the diff. i did that and she is seated. last time i thought i had it right but after looking once i got this one in, i see that i didnt have it right last time. bout to take a test run right after i post this. BRB
Advise to the next person having trouble seating your Driver axle.... REMOVE THE STRUT.
Old Dec 29, 2008 | 09:14 AM
  #58
KiNgJaMEs's Avatar
hey it seem to be done thanks for the help everyone and ill repost in about a week that should be enough time to make sure it done right.
Old Dec 29, 2008 | 03:49 PM
  #59
nissanmax2001's Avatar
Now you got the 95 running again SALE it...lol
Old Jan 4, 2009 | 01:27 PM
  #60
KiNgJaMEs's Avatar
UPDATE. everything seems to be in working order. big shout out to everyone that help me along the way.
boomerbrian
Oct 31, 2018 10:25 AM
RealityCheck
Oct 2, 2015 06:34 PM
The Wizard
24
Oct 1, 2015 08:47 PM
followthadollar
Sep 17, 2015 06:31 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
