Rubber burning...
Old Dec 14, 2008 | 03:31 PM
Thakidmeen's Avatar
Rubber burning...
So last week I was on the way to get my girlfriend for a movie, when I had the heat on, and all of a sudden a smell started coming through the vents that smelled like burning rubber. When I was at the light I saw smoke coming from under my hood so I pulled over, when I popped the hood there was smoke coming from behind my engine. Funny thing was, it would stop but when I turned the heat or the AC on it would start again, also when I tried to accelerate it started hesitating a little bit(Not since tho,) so I decided to wait it out, I thought maybe some plastic could of got stuck under the car and touched something that was hot. But I was crusing today and once again the smell came through the vents when I had the heat on, and I can smell it when I get out of the car, no smoke tho...any Ideas of what it could be??? Could it be the hot water tube??? I think I'ma take it to my mechaninc on Friday, I hope it's nothing serious...(The car hasn't been overheating or anything...) also it seems like I can also smell it when I just let the car sit idle. But it's been running great... IDK
Old Dec 14, 2008 | 03:37 PM
maxfever1987's Avatar
did u check underneath ur car at all? just to c theres nothing clnging on to ur muffler or the area arnd it. or ur splash shield somehow got caught to it i dnont know for sure but checking would be relieveing. good lcuk
Old Dec 14, 2008 | 08:31 PM
d1max2nv's Avatar
I have the same problem with my max, I have no idea what it is. but I seen the smoke from the back of the engine, and smell the burning rubber smell. If you figure it out please, do let me know.
Also the other day I was in work, and I had to heat a shaft that had grease on it, well it smelled the exact same. So I was thinking maybe some kind of boot broke under the car and just threw some grease on the manifold or something....
Old Dec 15, 2008 | 05:31 PM
ROCKART's Avatar
wants an I35
a burning smell from using the AC/heat is usually a belt that is rubbing against something.
have your belts checked - its a pretty easy and painless process and it should be clear where it is touching, because there will be black residue in the area.
Old Dec 28, 2008 | 03:13 PM
Thakidmeen's Avatar
^^^U know what I think THATS IT!!! Cause my belt has been squeeking...
Old Dec 28, 2008 | 03:18 PM
There you go.
Old Dec 29, 2008 | 06:27 PM
Thakidmeen's Avatar
Praise GOD! Thanks for all the help yall I'm gonna def get it checked out, it squeeks sometimes when I start the car then stops so I def gotta get the situation resolved....
shilov
Feb 19, 2024 09:40 PM
vingodine
45
May 21, 2016 12:46 PM
Maxboy23
Sep 9, 2015 10:37 AM
beerman1378
Sep 8, 2015 02:19 PM
maximusrising
Sep 4, 2015 06:31 PM
