To prevent future battery dying on me....
Old Nov 13, 2001 | 09:34 PM
AznStevie's Avatar
is there anyways...that i can shut off the headlight when i turn off the engine even if the switch is on?
Old Nov 13, 2001 | 09:40 PM
thebigsadler's Avatar
Re: To prevent future battery dying on me....
you have money?
your best bet is to talk to a stereo/alarm install place and see what it takes to wire up the headlights to an ignition wire.. that's all i know tho..
Old Nov 13, 2001 | 10:35 PM
Eric L.'s Avatar
Doesn't your car go beep beep beep when you leave the lights on after you turn off the engine and open the drivers door?? It's the same sound as leaving the key in the ignition.
Old Nov 14, 2001 | 06:11 AM
dwapenyi's Avatar
It probably does, but that sound is so low that its easy to overlook. I know I have.
DW
Old Nov 14, 2001 | 06:12 AM
Albertt's Avatar
Pay more attention >>
I habitually (read **** retentively) run my figers across the headlamp **** the turn signal stalk everytime I exit the car...just to make sure I don't leave the headlights on. I do this even in the daytime.
Old Nov 14, 2001 | 06:41 AM
max7's Avatar
When you walk into my college, on the door they have a sign that says:
"Have you turned off your headlights"
Buy those stickers and place them everywhere you go. This might help you remeber!
Old Nov 14, 2001 | 12:12 PM
AznStevie's Avatar
my car used to beep!!! but after i did the 5 speed conversion..it aint' beeping at me no more i miss that beep!!!!
Old Nov 14, 2001 | 01:35 PM
maxima42's Avatar
there is something called a battery buddy, it connects to the battery and will leave you enough power in the battery to start the car even if you leave the lioghts on.
www.batterybuddy.com
scroll down to the bottom of the page.
Old Nov 14, 2001 | 01:43 PM
SuDZ's Avatar
Re: Re: To prevent future battery dying on me....
I agree when it comes to rigging up electrical stuff like this some of those guys are crazy and can pull off anything.
SuDZ
Old Nov 14, 2001 | 01:49 PM
clee130's Avatar
Re: Pay more attention >>
Same here. I run a check-list through my head everytime I get out of the car. Chalk it up to having my having my battery die on me several times already due to having my headlights on.
Nothing like learning the hard way!
Old Nov 14, 2001 | 01:52 PM
SuDZ's Avatar
Re: Re: Pay more attention >>
Thats onew thing with my 5 speed. At least if I do leave it on there is always the option of push starting it if I am near a hill or something.
SuDZ
Old Nov 14, 2001 | 01:55 PM
matty's Avatar
Die-hard makes a battery that saves enough juice in the battery to let the car start up...It also has a Key Fob like your doors that is used to lock out the battery so nobody can start the car...also if its messed with after three turnes of the key you cant start the car until you "unlock the battery" I was gonna get it for my jeep but never did
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
maxima297
Sep 30, 2015 03:32 PM
