Weird lighting problem please help
Old Dec 24, 2008 | 02:11 PM
wirelessdude04's Avatar
Weird exterior lighting problem please help
So one of my headlights wasn't working so I popped my hood and moved the wires around. Problem solved doing that my mood lighting inside the headlight I have the cerfrio headlights the bulb went out so i'm thinking the contacts touched each other. So wth change the fuse, I change the fuse and nothing? I also checked the fuses under the hood and there all good. So right now my headlights work, but my other lighting doesn't bumper light, tail lights, fog lights etc... What could be the problem? I changed the fuse and all and its not blowing out or anything. Also when touching the two wires from my corner lights together i'm not getting a spark.. (I know not suppose to do but just checking)
Old Dec 24, 2008 | 03:33 PM
d1max2nv's Avatar
Check all your fuses, if your headlights are working it wont be your headlight fuse. there is a fuse if i remember correctly is an audio fuse that also controls the rear tail lights and gauge cluster lights. check all the fuses inside the car.
Old Dec 24, 2008 | 03:55 PM
im gonna check em all right now... Yea since my headlights work wont be the stalk..
Edit just checked them and nothing. I also have my foglights rewired to turn on with my parking lights. Maybe i'm thinking the relay blew out?
Old Dec 24, 2008 | 04:05 PM
nsnrider's Avatar
swap relays to see if one's faulty. You checked the "electronics" fuse inside the cabin?
Old Dec 24, 2008 | 04:08 PM
yup pulled almost every fuse out expect the odd ones. Like AC, power seats and stuff
Old Dec 24, 2008 | 04:11 PM
accordingtou's Avatar
VQ30 DE T
Isolate the fault by Checking all fuses again with test light or meter...
You may have knocked a ground loose as well.
I think its just a fuse though unless you melted two wires together. or have a broken connection...
Old Dec 24, 2008 | 04:16 PM
checked all the fuses... Where do you think i knocked a ground loose? Im thinking around my headlight where i was moving the wires around.
Old Dec 25, 2008 | 08:04 AM
checked the three grounding points two by the windsheild washer tank and the one by the fusebox by the fender and nothing
Old Dec 25, 2008 | 08:24 AM
Nopike's Avatar
Did you check the fuses under the hood? How are you checking the fuses? With a fuse tester? Just pulling and looking at them? If in fact all fuses are OK if there was a problem with your fog lamp rewire it could cause this type of problem. Maybe the connections for your fog lamp rewire came loose? Did you do some rewiring to install those cerfrio headlights, if so maybe you have a problem there.
Old Dec 25, 2008 | 08:26 AM
pmohr's Avatar
No more Maximas...
You checked all the fuses visually, or verified them all with a multimeter/test light?
Triple check every fuse in the interior fuse box, with something other than your eyes.
Also, don't skip over any fuses; some of the systems in the car are wired to oddly named fuses, stuff that seems like it has nothing to do with eachother.
Old Dec 25, 2008 | 09:17 AM
I dunno i just moved a few wires around and its fixed lol.. Thanks for the help guys
Old Dec 25, 2008 | 10:48 AM
alxdagreat1's Avatar
sounds like a bad connection or you can have a bad wire too it can be broken internally.... if it does it again check your connections that you rewired make sure that they are tight and check for continuaty with a meter try to find a way to hold the wires and wiggle the wires make sure that you don't loose continuaty most of the time the wires are broken near the ends
Old Dec 26, 2008 | 08:04 AM
njmaxseltd's Avatar
Not really, you simply but a bandaid on the problem.
You should really look for the cause, which I suspect was an open circuit or bad connection.
You had to do some wiring modifications to use those headlights, start looking there and you should find your problems.
Old Dec 26, 2008 | 09:30 AM
one of my foglights wires were loose
Lakersallday24
Nov 7, 2024 07:31 PM
tsi6001
Oct 3, 2022 10:23 PM
magneto112
Sep 10, 2015 12:52 AM
Samedi
Aug 13, 2015 04:05 PM
yat70458
Aug 3, 2015 01:16 PM
