High pitched noise at idle
Old Nov 14, 2001 | 01:58 PM
buckwilly4's Avatar
I have performed a search on this topic and have narrowed the noise down to either the alternator or belts.
The noise is a high pitched wine at idle. It only seems to kick in when the idle drops below 1000 rpm. It usually remains for a few minutes then goes away, then comes back. It totally disappears when I engage the gas. It also remains when the clutch is engaged and the rmps drop below 1000 rpm. I have tried just about everything. The noise is coming from around the passanger side by the belts but the belts all look fine. I had a mechanic quickly look at it and he said that they belts looked fine too. Anyone have any more suggestions besides taking it to the dealer? Anything else I could check. I know it has nothing to do with bearings....just doesnt seem to be the problem with the shown symptons.
Old Nov 14, 2001 | 02:33 PM
Asian_N02's Avatar
if you're still under warranty, take it to the dealer...it sounds like the belts to me...visually it might look okay...but that doesn't mean it's not the culprit...
Old Nov 14, 2001 | 02:40 PM
OgreDave's Avatar
high pitched sound at idle....
thats a v1 blower! hahaha
Old Nov 14, 2001 | 02:57 PM
teejnut's Avatar
i wish my car made a high pitched sound that was the cause of a V1 blower saw your car again ogredave last nite pulling into the new parking structure.
have your mechanic check the tension on the belts. that might be the reason. that was my problem according to my mechanic.
Old Nov 14, 2001 | 04:04 PM
tunedup's Avatar
ive got that too
its a whistling noise but i believe it was from my cone intake, because when i took it off the noise dissapeared...
Old Nov 14, 2001 | 05:35 PM
max808's Avatar
Re: High pitched noise at idle
you may want to check the belt deflection.
Old Nov 14, 2001 | 05:37 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Re: ive got that too
You are correct my friend. And when you turn your A/C off, the whistling goes quite.
Old Nov 15, 2001 | 09:43 AM
buckwilly4's Avatar
nope
It may be the belts because that is where the noise is coming from. Where is the alternator located in the car? I want to check if that is the noise also. I dont have an intake, only a k and n drop in. the car is almost dead silent at idle besides for the high pitch wine noise. And once you rev the car over 1000 rpm or give it gas over 1000 rpm regardless of the clutch being in or out...the noise totally disappears.
Old Nov 15, 2001 | 09:46 AM
buckwilly4's Avatar
And...
I adjusted my idle to 800 rpm with no a/c and the car still made the noise. When I unplugged the wire (dont remember the name but it is near the idle screw) as instructed when adjusting the idle, the cars revs jumped to 1500 rpms..the noise also totally disappeared. Once plugged back in and the revs fell to under 1000 rpms it made it once again.
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Andy29
Sep 29, 2015 05:32 AM
homewrecker
Sep 24, 2015 07:01 PM
