99 Maxima a/c Compressor clutch
Old Jan 6, 2009 | 05:42 PM
Stevenjc's Avatar
My compressor clutch is shot. I'm searching for a new or rebuilt one with no luck. Can any one point me in the right direction.
Thanks Steve
Old Jan 6, 2009 | 10:46 PM
SVI30's Avatar
Is it the clutch or the compressor itself? If the compressor freeze up, the clutch would slip too.
Old Jan 7, 2009 | 03:11 AM
Stevenjc's Avatar
It is the a/c compressor clutch. When the a/c is off you hear the bearings making excessive noise, when you turn on the a/c most of the noise goes away.
Thanks for the reply.
Steve
Old Jan 7, 2009 | 03:35 PM
SVI30's Avatar
Clutch is hard to find as most of the replacement compressors comes with clutch installed already.
The clutch comes off with a special tool. Kind of a "Y" with a key at each tip that fit into holes in the clutch face. Then turn the center nut to get it off. My old failed compressor is actually still around but I have no way to get the clutch off.
Old Jan 7, 2009 | 03:48 PM
Stevenjc's Avatar
Nissan has the clutch only for $425.00.
Old Jan 7, 2009 | 04:04 PM
alg@nemobile.com's Avatar
Thanks Steve
Autozone has it for less than 300 complete won't have to rebuild anything. I just did it
Old Jan 7, 2009 | 04:33 PM
pmohr's Avatar
No more Maximas...
FYI, your sig pic is way too big. 1024x763? 550x325 is the limit.
http://forums.maxima.org/4th-generat...g-sig-pic.html
Originally Posted by phenryiv1
Since people seem to have FORGOTTEN the rules...
As a courtesy to others, please avoid extra wide signatures. They are annoying to others. When your sig is so wide that it makes other users scroll to read the whole thread it is annoying and time-consuming. A good guide is 550 pixels wide at the widest. Also, please avoid extremely long signatures as well. 325 pixels will be considered the limit of signature height.
Old Jan 7, 2009 | 04:49 PM
SVI30's Avatar
Try this place. They may be able to sell you a clutch.
http://tcw-us.com/compressor_apps.as...ssan&year=1998
I got my factory compressor from Meridian in San Diego. Although clutch is not listed, it's worth a try.
Old Jan 7, 2009 | 04:53 PM
Stevenjc's Avatar
I found this in the stickys
http://forums.maxima.org/4th-generat...updated-2.html
Post # 50
Old Jan 7, 2009 | 05:06 PM
SVI30's Avatar
Yes, the compressor don't need to come off the car. You can get to it from the right side wheel well.
http://i48.photobucket.com/albums/f2.../DSCN9302a.jpg
In this pix I dismounted it to get the alternator off but left all the hoses intact.
Old Jan 7, 2009 | 10:00 PM
quique's Avatar
I just had the same problem with mine. I just replaced the whole compressor with a rebuilt one though. I found it for $145 for the reman compressor. It was from a shop in Van Nuys. If you are in so cal id reccommend you go there.
Old Jan 8, 2009 | 05:08 AM
Turbobink's Avatar
it sounds like the issue is the pulley bearing.
that being the case, just the bearing can/needs to be replaced.
remove the compressor clutch plate and the pulley.
take the pulley in to a local A/C shop.
They can press out the old bearing and press in a new one.
the cost should be somewhere b/t $30 and $60.
Old Jan 8, 2009 | 07:44 AM
I appoligize and will take care of that asap
Old Jan 8, 2009 | 01:23 PM
Stevenjc's Avatar
How am i going to find that specific bearing,I guarantee Nissan doesnt sell it.
Old Jan 8, 2009 | 07:22 PM
wxm's Avatar
wxm
Stevenjc, take a look at this thread (http://forum.ih8mud.com/80-series-te...sor-noise.html). It is for LandCruiser, but on post #7, the guy specializes in a/c business. You can contact him (you might get "mud" discount if you pm him directly from the forum - mud users usually take care of each other there.). Following the thread, you may even get him to press the bearing on.
Good luck
Old Jan 9, 2009 | 04:36 AM
Turbobink's Avatar
just take the pulley to an A/C shop... they'll have the bearing.
for crap's sake... there is no factory in Malasia making A/C pulley bearings for only the Nissan Maxima to subsequently supply them only to the pulley bearing underground blackmarket.
that bearing is used on tons of cars across lots of makes and models.
the A/C shop will have it.
they may not stock it as a bearing for a '99 Maxima A/C pulley but if the one they have is the same size and type, who gives two sh@#s.
that's why you need to take the pulley to them... so they can properly size and type the bearing that's be coming out of your pulley.
Old Jan 9, 2009 | 06:55 PM
Stevenjc's Avatar
According to my mechanic it can be done, but often the compressor fly wheel easily warps from heat when it seizes. He stated it is more reliable to just spend the extra money and do right with a new clutch.
Old Jan 10, 2009 | 02:34 AM
azn_mint's Avatar
My a/c clutch was shot too, and I just went to a local junk yard and picked mine up for 100 dollars. and it worked perfect! Maybe try calling around, you might be lucky and find one in working order.
acw
Aug 13, 2015 12:50 AM
MikesChevelle
Aug 10, 2015 10:53 AM
sc10692
Aug 9, 2015 09:37 AM
