found fuel leak, now what???
Old Jan 9, 2009 | 01:01 AM
max ride 41's Avatar
i thought it was the injector, still smelled the gas after i replaced it. so, i was at work and got a flashlight out after i started her up, facing the engine, i could see fuel dripping on the left hand side, could'nt tell if it was the rubber hose because it was wet all the way up to the metal tube and around the fitting as well. it dries up after she warms up, rubber hose???? what else could be leaking and can the metal tube going up to the rail be loose???? thanks>>>
Old Jan 9, 2009 | 06:05 AM
pmohr's Avatar
No more Maximas...
Did you try tightening up the clamps for the crossover hose for the fuel rail?
Old Jan 9, 2009 | 06:57 AM
no actually, i have'nt. it was dark and i could'nt see them very well. i just wanted to see if it could've been something else. if that does'nt do it, where do i go next?
Old Jan 9, 2009 | 06:59 AM
pmohr's Avatar
No more Maximas...
Then you look for wherever else it's leaking from
Old Jan 9, 2009 | 07:06 AM
1chewabacha1's Avatar
^^^Yeap... that's pretty much all you can do... Cover it w/ JB Weld + Duct Tape.
Old Jan 9, 2009 | 07:08 AM
mtrai760's Avatar
'Trynna' is not a word
If your talking about the fitting to the fuel pressure regulator, then it could be leaking from the O-ring on the fuel rail adapter, from the regulator itself (though I would be extremely suprised) or from the fuel line.
Last edited by phenryiv1; Jan 15, 2009 at 01:02 PM. Reason: merged a troll post into yours.
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
ag90fox
Sep 9, 2015 12:22 PM
Hdnseek
Sep 9, 2015 05:55 AM
