Fog lights wiring question
Old Jan 9, 2009 | 11:11 AM
tosheto's Avatar
Here is the deal. I have 98 GXE and I have done couple things to it, but now I want some fogs. I know that the car has the wiring, I also bought the fog light key or whatever is called and I am looking for some fogs. But someone told me that I can not put fog lights on GXE. Any ideas on how I can do maybe a rewiring?
Old Jan 9, 2009 | 12:22 PM
UncleMax98's Avatar
My car is 98 GXE with the Security and Convenience package. Fog light wiring and connectors are already prewired. If you get the fog light kit from Nissan, everything is plug and play.
Old Jan 9, 2009 | 01:22 PM
tosheto's Avatar
I have tried and did not work. Do you have fog lights? are they from Nissan or aftermarket?
Old Jan 9, 2009 | 01:35 PM
pmohr's Avatar
No more Maximas...
You tried installing the whole package and it didn't work? Your first post says you haven't even bought the fogs yet.
Old Jan 9, 2009 | 04:21 PM
tosheto's Avatar
I haven't bought fogs yet. But I borrowed some aftermarket just to try if they will work and they did not!
Old Jan 9, 2009 | 04:22 PM
pmohr's Avatar
No more Maximas...
So did you not have power at the connectors, what? Did you install the relay and the fog light equipped stalk?
Old Jan 9, 2009 | 05:53 PM
UncleMax98's Avatar
My foglight kit is made by Nissan.
Old Jan 12, 2009 | 04:42 PM
tosheto's Avatar
there is no power at the connectors. I installed the stalk myself. I got it from 99 SE, but have not played with the relay yet.
Old Jan 12, 2009 | 04:44 PM
pmohr's Avatar
No more Maximas...
So you have no relay installed? That will be a good cause for no power at the connectors. Did you install the fuse for the fogs?
And why do you call your car a 'GSE'?
Old Jan 12, 2009 | 04:46 PM
tosheto's Avatar
My stalk is the Nissan one, but I will get some aftermarket fog lights
Old Jan 12, 2009 | 04:52 PM
tosheto's Avatar
there is a fuse, but most likely no relay.
the car is 98 GXE with bunch of SE stuff on it.
Old Jan 12, 2009 | 04:53 PM
pmohr's Avatar
No more Maximas...
Well, obviously you won't get power without the relay installed...
And that just makes it a modded GXE.
Old Jan 12, 2009 | 04:59 PM
tosheto's Avatar
When i get a free minute i will check out what's up with the relay.
about the name i just like GSE. sounds cooler. most people think that it is SE.
thanks for the help. i appreciate it !
Old Jan 15, 2009 | 02:37 PM
tosheto's Avatar
I got it all going. Now everything works perfect! thanks everyone
Old Jan 15, 2009 | 02:38 PM
pmohr's Avatar
No more Maximas...
You should post how you fixed your problem to help others that find this thread through search.
Old Jan 15, 2009 | 03:34 PM
tosheto's Avatar
I agree with that. And I will do it, but first I will take couple pictures to help explaining what I did. I do not know why people say that you can not put fogs on GXE because that is not true
Old Jan 22, 2009 | 01:16 PM
tosheto's Avatar
Here is how I fixed my problem:
I went to a junk yard and they had 99 SE. I got the fog light stalk from it and a blue relay with 4 pins. It is the same as the fog light one. I switched out the stalk and put the relay in the relay box by the coolant tank. After that I got some aftermarket fog lights and installed them. Now everything works perfect.
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
98nismomax
Aug 13, 2015 12:44 PM
