Engine/Motor Mounts
Old Jan 14, 2009 | 08:00 PM
NeeDog20's Avatar
Engine/Motor Mounts
Probably a n00b question, but how many motor mounts do we have?...4?...one set in the front (left and right) and one set in the rear (left and right)?...do we have a transmission mount also?...
Im guessing Energy Ssuspension only sells them in a set of two but doesnt disclose how many we actually need...
Taken from Energy Suspension Website:
1995-03 Motor Mount Replacements (two torque mount positions only) 7.1114 (57)
Old Jan 14, 2009 | 08:10 PM
pmohr's Avatar
No more Maximas...
We have 3 motor mounts, one trans mount. Timing cover, trans, and front and back of the block.
The ES inserts are for the two lower mounts on the crossmember; the ones that take the brunt of the twisting force on the powertrain.
Old Jan 22, 2009 | 06:04 AM
loxety's Avatar
Wonder which need to be replaced most often? I think mine needs the trans and timing mounts replaced. I get the shake when taking off from a stop and when I accel hard and the engine shakes during each shift.
Old Jan 22, 2009 | 06:28 AM
Puppetmaster's Avatar
The front and rear mount inserts on the cross member are the ones that typically go bad and need to be replaced, since like pmohr said, those take most of the beating. The Energy Suspension set is pretty much all you need, unless your car has other mount issues. Remember, these are just motor mount inserts, so you will need to find a way to press out the old inserts and press in the new ones. You reuse the motor mount brackets that bolt to the cross member.
Old Jan 22, 2009 | 11:46 AM
Ramius83's Avatar
On the 02+ 3.5 Liter Maximas/Altimas, we see the Passenger side (crnak pulley side) mount go bad WELL before the two cross-member mounts go. But nonetheless, 95-01 front/rear mounts go bad often.....
Old Apr 3, 2009 | 09:31 AM
S1cTech's Avatar
oh damn. So these are only the red things that are pictured? Not the other black metal mounts in the picture as well?
Old Apr 3, 2009 | 09:40 AM
pmohr's Avatar
No more Maximas...
What picture?
And 2 month old thread FTL
The metal frames are the remnants of the stock motor mounts, you press/burn out the rubber internals and press in the new ES mounts.
Old Apr 3, 2009 | 10:15 AM
S1cTech's Avatar
Originally Posted by pmohr
What picture?
yah, I don't have that ability. Not a lot of shops around here that press Motor mounts out of the mount. >_>
And 2month old thread or making a new topic? Which do you prefer?
Old Apr 3, 2009 | 10:19 AM
pmohr's Avatar
No more Maximas...
Searching, personally
Anywhere you can find that has a press should be able to do it without a problem, really. Failing that, you could just torch the rubber out, if you're not worried about polluting the environment, heh.
Unclejunebug
Apr 2, 2016 05:42 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
sliptap
Sep 30, 2015 05:57 AM
