ecu question
Old Jan 23, 2009 | 02:47 PM
mistur_sleepyass's Avatar
ecu question
got a call the other day from my mechanic and he told me that after being on the phone with nissan techline they concluded that my two nessed up crank sensors caused my ecu to go bad so now i am on the search for a new ecu.
my mechanic said i can grab an ecu from a 96 or a 97 maxima as long as it was from an se model and that it was manual. but as i started searching and finally found and ecu and gave them a call they asked me for the service number of my ecu to match it.
so my question is do the service numbers of the ecu's have to match up?
Old Jan 23, 2009 | 03:07 PM
JtzMax's Avatar
Whatchyou say?
Not that I am aware of, no. You just can't use an ECU from a 99' IIRC. 95 - 98 should be ok though. Also, the MT and AT are different, just bare that in mind.
Not sure that they have it just right either mate. Not very likely that a CPS and CKPS would cause an ECU to go bad. Maybe the other way around I could see.
Also on a side note - I don't know there's any difference in the trim level (GXE / SE / GLE) for the ECU.
Old Jan 23, 2009 | 04:06 PM
pmohr's Avatar
No more Maximas...
Yea, never had a problem mixing and matching ECUs with different numbers on them. 95-98 are interchangeable (with regards to actually getting the car to run, emissions are a completely different matter), '99 is the odd man out.
The only trim difference you're going to find is the speed limiter, and on 4AT cars whether or not it will control the electric front mount.
Old Jan 24, 2009 | 11:35 PM
so any ecu from a 95 to a 98 would work in my car as long as it's a 5 speed right?
Old Jan 25, 2009 | 12:14 PM
pmohr's Avatar
No more Maximas...
To do nothing other than have the car run? Sure, most likely. To have it run without CELs? Just make it easy on yourself and go with the same year ECU.
Old Jan 25, 2009 | 12:19 PM
MaXiM@KiD's Avatar
MaXXiN
Yes thank to Pmohr I figured my out the ECU I have (97) has a fuel pump control module that my actual car 98 doesn't come equipped with. I just bought an ECU for a 98 this weekend and swapped it in...I'm going to put it up for sale if you want you can have first dibs...I can ship it from my job if you want it let me know PM me
Old Jan 25, 2009 | 12:51 PM
ThurzNite's Avatar
my 97 gxe 5sp ecu is for sale, $125
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
junito1
Sep 23, 2015 12:14 PM
Socalstillen
Sep 20, 2015 11:46 PM
QueensMAX
Sep 15, 2015 04:14 AM
