need some sensor help!!!
Old Jan 24, 2009 | 12:05 PM
bcmaxima96's Avatar
hey sup guys,
so my check engine light is on n now i need to get my inspection done so i needed to fix whatever was wrong. When i ran the coeds it said it was my intake air temperature sensor. So i went got the new sensor hooked it up but the cel is still on. Any ideas how i can remedy thois or figure out why its still on seeing as theres no other codes coming up. Oh and even after i put in the new sensor the code still comes up.
thanks....
Old Jan 24, 2009 | 01:35 PM
pmohr's Avatar
No more Maximas...
Did you test either sensor? Check the connectors for corrosion? Check continuity from the connector to the ECU?
Did you even reset the codes after installing the new sensor?
Old Jan 24, 2009 | 03:09 PM
G4nismo's Avatar
he most likely didn't do any of that...
Old Jan 24, 2009 | 03:48 PM
TunerMaxima3000's Avatar
Pmohr on the prowl
Old Jan 25, 2009 | 06:15 AM
bcmaxima96's Avatar
i did reset the ecu but i havent checked the connectors for any corrosion yet. I'll check it out today. And what do you mean by continuity??
Old Jan 25, 2009 | 12:01 PM
G4nismo's Avatar
a closed circuit basically
Old Jan 25, 2009 | 12:28 PM
pmohr's Avatar
No more Maximas...
The definition of continuity: an uninterrupted connection.
Basically check to make sure the harness isn't broken between the connector in the engine bay and the ECU connector.
Old Jan 25, 2009 | 01:16 PM
djluski's Avatar
take off the battery cable for 24 hours. helps to do this every once in a while. not only will it reset the computer but it will have to relearn everything about the engine's performance. of and it will clear your CEL
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
