Scary brake problem at -25.
Old Jan 25, 2009 | 12:14 PM
oVeRdOsE's Avatar
Hi,
those days, the temperature's low, around -25-30 celcius.
when the car's cold, I can brake normally like 2-3 times. And sometimes the brake pedal doesnt move a inches after 2 streets corners!! Like if something block the pedal. I pump hard 5-6 times to get the brake back.
= I cant stop the car! Hand brake's my last resort.
Oil's good, abs's off.
Can the oil freeze? Actually is very dangerous...
tips.?
Old Jan 25, 2009 | 12:19 PM
dgeesaman's Avatar
Maintenance Monster
Sounds like you NEED a new master cylinder.
I think you should take it to a good shop and let them sort it out. No fooling around with troubles like this.
Dave
Old Jan 25, 2009 | 02:08 PM
maxx0831's Avatar
i would say the mass cylinder as well.. get that taken care of ASAP. I got a a brake problem to that i got to get checked out to. When it rains my pedal drops and vibrates. becareful
Old Jan 25, 2009 | 02:26 PM
maxfever1987's Avatar
i got a very similar problem my brake pedal is hard to press as well, but my problem is on and off, i changed the brake booster but that didnt help, i havent changed the master cylinder but if u do let us know wat happens
Old Jan 25, 2009 | 05:15 PM
Carrera's Avatar
Look directly under neat the master cylinder to see if it is wet. If not it may be leaking internally. It is deffinatly a master cylinder and something you need fixed asap. If the fluid is fine then it is prolly leaking internally. Get it fixed!
Old Jan 26, 2009 | 02:08 PM
oVeRdOsE's Avatar
Thanks alot,
I'll check it soon, i dont use the car for the moment.
btw, I dont lose any oil, the tank's full. Probably somethings wrong with the master and the -30 weve got this week.
Old Jan 26, 2009 | 03:33 PM
Kevlo911's Avatar
Kevlo for President
The fluid also prob has moisture in it so the cold weather is causing the moisture to freeze. Make sure you use a good synthetic fluid when you replace/repair the master cyl
Old Jan 26, 2009 | 05:30 PM
ruckus1027's Avatar
yeah plus one on kevlo...it could be frozen lines....when was the last time u had a brake bleeding?
Old Jan 27, 2009 | 08:20 PM
heynow's Avatar
Kevlo makes a good point. I've had a similar thing happen over two years ago. I put my car in gear and pull out of my driveway. As soon as i go for the brake it became hard as a rock and i'd barely stop. It would be okay after that, but scary nonetheless. The problem went away after a complete brake system flush. Seeing how brake fluid is hydroscopic and absorbs moisture. It'd only make sense that if the brake fluid hasn't been flushed for too long, the acumulated moisture can freeze.
Old Jan 28, 2009 | 08:49 AM
ruckus1027's Avatar
ive thought about it....kinda long shot but it could be that all 4 caliper brakes are frozen
Old Jan 28, 2009 | 09:00 AM
oVeRdOsE's Avatar
Nope, because I can use it 2-3 times before the block.
It's like if the car's off and you use your brake pedal. It's comming harder to push it, until you reach the max pression.
The master cylinder doenst work even if the engine's on.
I'll make a check up, oil change and bleed.
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Johnny9595
Sep 16, 2015 07:20 PM
bbsitum
Sep 11, 2015 04:55 PM
slowlifer
Sep 8, 2015 05:53 AM
