anyone ever gut there precats? cheap hp.
Old Nov 15, 2001 | 05:11 PM
conig's Avatar
was just wondering if this was worth trying or if even possible I did it to both of my old contours and got good gains.
also if anyone has done this do you happen to have dynos?
worthless info: on contours its dyno proven to loose horsepower by removing the bends in our y-pipe which is why I'm wondering if the stock y-pipe with a new flange thats not crushed would be worth it. also supposedly having a hollow precat increases scanvenging as an expansion chamber or something which us supposedly the same as a collector.
Old Nov 15, 2001 | 05:37 PM
clee130's Avatar
About gutting the cats, read the "4th gen FAQs" thread above.
Old Nov 15, 2001 | 10:06 PM
Nealoc187's Avatar
SLOW
It sounds like you have quite a bit of technical knowledge which is good. But a Y pipe gets rid of the precats altogether and they aren't very expensive. I got great gains from my Y pipe... .41 in the 1/4 and a full 4 mph in the traps.
Old Nov 16, 2001 | 10:41 AM
conig's Avatar
I know a y-pipe gets rid of the precats I'm was asking one of those what if questions or one of those why not questions.
cause right now I can't afford the y also was wondering the hp per $$ between the to I'll most likely try it anyway and poat some results.
thanks for your help.
Old Nov 16, 2001 | 10:47 AM
theblue's Avatar
think about it this way... if you destroy your stock y-pipe (they cost about $1000 from a dealer I think) then what if you have to replace it when you sell your car? you can buy a y-pipe for $200 ??
Old Nov 16, 2001 | 11:28 AM
conig's Avatar
good point but have you ever checked out a y-pipe before you bought your car you would most likely never notice
plus florida doesn't have emmisions.
Old Nov 16, 2001 | 11:36 AM
conig's Avatar
Old Nov 16, 2001 | 02:32 PM
ghettomaximaz's Avatar
question
if i install a warpspeed y-pipe, is there any way for me to get the precats installed again on this new y-pipe?
thanks
gmax
Old Nov 18, 2001 | 11:28 AM
bmfjeep's Avatar
Re: pre-cats
thanks
gmax
You will not be able to reinstall the factory precats, unlike most of the domestic precats which look like a bullet shaped cylinder and can simply be cut off and replaced the Nissan precats are made of what looks like cast iron and are extremely difficult to remove from the stock Y pipe asembly.
Best solution is put your stock Y pipe in a box and reinstall it when you sell your car. That is what I did with mine and the stock converter, airbox etc.
Dallas
WarpSpeed Performance
Pnjboyzz
Oct 7, 2015 10:47 PM
worldwiderecognized
Sep 24, 2015 06:56 PM
pears
Sep 18, 2015 05:25 AM
