My motor got loud recently.
Recently after my Front Right Heated O2 Sensor went (threw a code) the motor has been getting particularly loud. Not exhaust loud, but like a loud motor above 50km per hour. Would that code as well as a Closed Loop Control, EGR Solenoid, and Multi-Cylinder Misfire cause the loudness.
The weird thing is that the car isn`t misfiring.
i just replaced my oil pan, but that wouldn`t have anything to do with it.
Any ideas
Any ideas
May be a tranny bearing...but it sounds very loud for a bearing if thats what it is. I just had my tranny replaced recently. Fluid seems to be fine. No hard shifting, nothng like that.
I've tightend the belt on the altinator recently cause it was loooose as $hit and was squeelig on startup. Now it doesn't squeel, but i don't think over tightening would cause something loud like that.
Anything else?
i'm not up on the different sounds that all of those make. But it is more of a really loud humm and slight vibration lets say above 2000 rpm and above 50km/hr. Not a Pinging sound, or tapping, or knock.
Anything else?
Anything else?
check your belts?
Sounds almost like the whole motor is vibrating rapidly.
A loud hum and intermittent vibrations like every 1/2 second, almost constant but not quite. Not a wheel bearing noise, it's to instrusive. Not a ball joint wheel vibration cause it only happends when the car is over 2000 rpm and over 50km/h and i just had both ball joints replaced 2 months ago
i have an audio file, but i can't upload it cause it's from my blackberry and its an .amr file. Quicktime plays it but i can't upload it to photobucket or anythnig...
i don't think it would be that tho...it doesn't sound like an exhaust leak. More like a bearing. i noticed today on the way home, that going from say 120km/h down to 70 or 80 the sound gets really deep and the vibration gets slightly more noticable. Seems to be that would point to a bearing. Do ya think?
BTW, the damn flat rate boxes just got here a minute ago, the customs forms should be here tomorrow or monday so hopefully it shouldn't be any later than tuesday.
[QUOTE=Bassbreaker;6857336]i don't think it would be that tho...it doesn't sound like an exhaust leak. More like a bearing. i noticed today on the way home, that going from say 120km/h down to 70 or 80 the sound gets really deep and the vibration gets slightly more noticable. Seems to be that would point to a bearing. Do ya think?
QUOTE]
You are probably right, just something to inspect and consider. Mine was droning vibratiion noise at 2000 RPM regardless of speed.
QUOTE]
well my pop diagnosed it today. He went for a run with me and he said it was the passenger side wheel berring race. When i had a corolla and the wheel bearing went, it was a real grinding sound when i took a turn. The maxima just hums and it doesn't seem to grind when i take a turn. All cars are different i suppose. I'm picking up a bearing on monday or tuesday and i'll let you know if thats what it was.
AaronL
08-08-2020 10:31 AM
Unclejunebug
04-02-2016 05:42 AM
Kyle Lee Cleveland
09-28-2015 07:58 AM
