ACK! - 96 wont start?!?
Old Feb 12, 2009 | 09:44 PM
  #41
cvsmaxima's Avatar
Originally Posted by pmohr
Give that grounding thing a try?
its funny that you mention that. I looked and there is actualy already 2 additional 10g wires running from the ground to the chassi
Old Feb 13, 2009 | 08:59 AM
  #42
ATTappman's Avatar
Originally Posted by cvsmaxima
so the question is: would this alone keep it from firing?
(test is for ohms, there is suposed to be some level of resistance, but the test yields no continuity)
The condenser is wired in parallel with the primary ignition circuit. I think it's there just to provide some capacitance to dampen out electrical noise. You can unplug it from the harness and the car will still start. If it's shorted, though, I'm not sure what would happen, but maybe it provides a path to ground that starves your coils of current. But you said you got spark...seems like a shorted condenser would blow a fuse anyway.
Manual says resistance across the terminals should be 1 M-ohm. Your multimeter ought to be able to tell the difference between 1 M-ohm and overlimit, but maybe not?
Don't think the parts stores stock this part.
Old Feb 13, 2009 | 12:09 PM
  #43
cvsmaxima's Avatar
replaced it .. still nothing..
Old Feb 13, 2009 | 01:44 PM
  #44
cvsmaxima's Avatar
ok cleared codes... new code is 0505 ...
Which says that everything is "ok" ?
can anyone verify this?
Old Feb 13, 2009 | 01:52 PM
  #45
cvsmaxima's Avatar
ok i verirfied in the fsm 0505 is the same as P0000
still wont start
i have fule, air, spark..
the only thing left is timing right?
if the freekin thing managed to skip a tooth or two... ??
what else could happen to the timing?
i know that the tiing light says that the main crank is in time.. but what about the headers? is there a way to verify that they are in the correct time?
there is a pinging sound , but i assumed until this point that its just cause its been sitting with no oil preasure for so long.
if anyon has any ideas, or wants to hear the thing try to start, please feel free to give me a call at (seven seven five) two three three - two seven four five. i'll call you back if long distance is the issue.
PS me cell is dead and charging atm, gime about 20 - 30 mins if you want to call, or leave a message.
Old Feb 13, 2009 | 11:34 PM
  #46
snowboi1289's Avatar
Have you tried to see if you have a lose vacuum line, or a leak in a vacuum line? Also, get a smal sample from the engine oil, if it has large or thin chunks of metal, the oil hasny been changed for a long time, it thats what it may need. I've looked over my car 5 times already, trying to figure out what it could be, but I'm sure everybody (including me) is stuck.
Old Feb 16, 2009 | 11:34 PM
  #47
cvsmaxima's Avatar
STEP 2 : ...
ok so after everything i called a mechanic friend of mine (who was finaly back at work.. geez he thinks hes allowed to take days off) and i told him everything... and then he listened to it for 15 seconds... and said :
"those guys [at the place i got it] lied.. it was never preasure tested... i could prove it for ya, but im telling you.. there is ZREO compression on more then 1/2 of those cylindars..."
So i told him i had a line on a motor from a 98 max that had been killed in a rear end accident, preasure tested, 180-190 in all 6 and 60-90psi oil preasure, and under warrenty for 30 days unlmited mialage for only $450...
he of course said .. "so why are you talking to me and not going to get that motor?"
so 2 days later i have the motor installed, and running!!! YEAH!!
and then STEP 2:
... i think that the transaxle input shaft drive barrings and seals are shot.
i read several forum posts here and the symptoms are exact... trans noise, leaking gear oil.. (relitivly quick) from the belhousing..
and then the wife chimes in.. "F*it... sell it..."
Old Feb 17, 2009 | 04:09 AM
  #48
Bassbreaker's Avatar
and then STEP 2:
don't listen to her man. My fiencee said the same thing when i bought mine. So I never listened and put a new tranny in it. And I have about the same amount of miles on mine. Enjoy your car. Whats a little re-build? Or a new tranny? Or a 5 speed swap :P
Old Feb 17, 2009 | 10:52 AM
  #49
cvsmaxima's Avatar
lol tru... actualy.. what id really like to do since it is a VQ series motor is get a 6MT <drool>...
but the problem is FINDING one..
i have called every yard atound and havent found a 5MT yet
Old Feb 17, 2009 | 11:03 AM
  #50
I SENT ONE TO THE DUMP NOT TO LONG AGO. DID YOU TRY WWW.CAR-PART.COM?
  #51
sorry for the capps...i'm working on Auto Cad
Old Feb 17, 2009 | 11:07 AM
  #52
http://car-part.com/cgi-bin/search.cgi
look here man
i just found 6 or so in eastern Canada..you should be able to find one in the states
EDIT: sorry that don't work...just use car-part.com...yo'll find one
Old Mar 5, 2009 | 07:44 PM
  #53
cvsmaxima's Avatar
look here man
UPDATE: New transmission installed everything great now...
just one question left....
I am running full synthetic oils and it seems that my oil light likes to come on occasionaly... ususaly after turning a tight corner. I checked it and its fine... so what the heck is goin on?
-cs
Old Mar 6, 2009 | 04:47 AM
  #54
fflint_18's Avatar
-cs
Had the same problem a few years ago on my Integra. before you jump to any bad conclusions try changing the connection at the pressure sender.
Then change the sender.
If it still occurs you probably have a lower thasn needed pressure or a partially clogged pickup.
Mine was caused because the oil pickup in the pan was partially clogged and when I turned one way it starved the pump.
Ended up ruining the pump.
Good Luck.
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
trungg86
Sep 4, 2015 04:58 AM
