Backup Projectors.. Stock Wiring?
Anyone know if the stock back up light wiring will handle a set of projectors
I noticed that a set of mini projector fogs will fit perfectly into the reflector housing on my G2 tails and am curious if I could simply drop them an and connect them to the stock wiring.
Isnt the stock bulb rating like 13w? Kind of defeats the point of putting in projectors if I cant at least get 25w-35w out of them.
Maybe some of those 48 smt boards would be a better option.. I just think a silver set of projectors would work better and look better as well.
Wow ... Ilya I like that! Are those mounted in the stock housing? Using the stock connector?
to the OP, if you want to run brighter back up lights, why not go with the 921's? If you are talking about mounting a pair of projectors inside the brake light housing, it might be a tight fit.
I'm tired of backing up while hanging out of the window
Has anyone done a LED board for the front side markers? Every bulb I have tried looks like shiz and there isnt enough room to go bigger with the bulb size. I found some cheap 12v amber boards on ebay that look like they will fit.. I just dont know if I can oven heat the clear corners and get them open to install the boards.
He does everything (headlights, tails, bumper lights, side markers, etc.)
The Frye
Sep 2, 2021 11:03 AM
James92SE
Oct 8, 2015 04:57 PM
