Can you tell what problem is causing this sound?
Old Feb 13, 2009 | 06:44 AM
jxkim's Avatar
i know the only way to know for sure is to jack the car up and take a look up close. but its cold outside and i rather bring it to a shop. usually i like to buy and parts ahead of time to save money and time. hopefully maybe someone on the org has had a similar problem?
anyways... whenever i make a right turn, on the driver side front wheel i hear a metal scratching noise. it kind of sounds like if you were rubbing metal slightly against a spinning metal disc. the sound volume goes up and down which leads me to believe its something loose?
i have stock rotors, pads, calipers and the 97-99 se 16" rims
i did recently get my suspension reinstalled (had to replace the upper strut bearings)
Old Feb 13, 2009 | 07:42 AM
maximadudeIIs's Avatar
Did you check the wheel bearings or CV joints?
Old Feb 13, 2009 | 07:51 AM
Snypa's Avatar
what about that dust sheild..i think thats what its called.But your right...best bet is to jack up and inspect.
Old Feb 13, 2009 | 07:55 AM
Feldman's Avatar
^+1 on dust shield
Old Feb 13, 2009 | 08:05 AM
pmohr's Avatar
No more Maximas...
If it is the dust shield behind the rotor, no need to even jack the car up. Just get a screwdriver and a hammer, bang it back through the spokes in the wheel.
Old Feb 13, 2009 | 09:03 AM
Nopike's Avatar
I had a similar problem recently, drivers side noise when making a right turn, it ended up being the front sway bar end link. You could hear the noise if you pushed down on the car also. Your problem/noise may be different but that is something to consider.
Old Feb 13, 2009 | 03:02 PM
+1
To the OP, how loud is the "metal scratching noise"?
Old Feb 13, 2009 | 08:03 PM
jxkim's Avatar
was the noise even similar to the one i described?
and first thing tomorrow morning i will do a simple dust boot check
hopefully its something that simple
Old Feb 13, 2009 | 08:11 PM
Leo_Koneval's Avatar
This is probably not your case but when I took of one of my wheels to check something when I put it back, I didn't tighten the lug nuts enough and after a while the nuts came loose and whenever I drove the one wheel would make a loud grinding noise. Until I realized that some lug nuts were missing and so I tightened the hell out of the remaining ones and bought new ones and tightened the hell out of those too
Old Feb 13, 2009 | 08:15 PM
Nopike's Avatar
[I] It sounded more like a squeaking noise not really metallic. I memtioned it because it was occuring on right turns. It also happened if you pressed down on the front end. Your issue is probably something different but I thought I would mention it just in case.
sctludwig
Sep 1, 2022 01:32 PM
DJLAX152
May 4, 2021 11:46 AM
97_GXE
Sep 15, 2015 06:47 AM
A32goldylocks
Sep 2, 2015 06:39 AM
