Door Panel Removal
Re: Re: Door Panel Removal
Originally posted by NJ95gxe
...and how does one remove the inserts?
i've got leather waitng to go in. but, after taking the panels i don't see how.
thanks
thanks
I think I know what you are talking about - you need to remove the entire door panel and you will see that the cloth or leather insert is held in place by metal tabes that are passed through the door and folded down on the backside of the panel. HOpe this helps.
whaa???
i had no inserts. is this not true for 97+. i have a 95 and had no inserts. what i did was cut a piece of leather. then i got that stuff that goes in screen doors. you know the deallys that they use to secure them.. anyway if this wasnt descriptive enough lemme know
![Confused](https://maxima.org/forums/images/smilies/confused.gif)
The inserts look very much alike except that one is cloth and, the other leather.
Pictures
Hi, follow the linkhttp://www.geocities.com/nj95gxe/95_...oor_Panel.html And you'll notice that I don't have where to pass the metal tabs trough. I might just rip off the stock inserts. And use a combination of the tabs and glue to hold the leather inserts in place. That would make the swap permanent. But, I think that I could live with that. ![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
Any opinions before I take the steps of no return?
Re: Pictures
Hi, follow the linkhttp://www.geocities.com/nj95gxe/95_...oor_Panel.html And you'll notice that I don't have where to pass the metal tabs trough. I might just rip off the stock inserts. And use a combination of the tabs and glue to hold the leather inserts in place. That would make the swap permanent. But, I think that I could live with that.![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
![got me](https://maxima.org/forums/images/smilies/ne_nau.gif)
Re: Re: Pictures
The only thing I would say is can you just make the holes you need in your panel for the inserts? That would probably be easier and not so permanent.
Thanks for your input.
95naSTA
09-21-2015 06:50 PM
lkiller123
09-21-2015 03:00 AM
carid
09-17-2015 05:00 AM
