Clutch Hydraulic System...
Old Feb 22, 2009 | 09:38 AM
michaelp's Avatar
What is the purpose of that T in it for the bleeder line? It seems useless to me, unless its also some sort of clutch damper? My Z31 had a master, clutch damper, and slave, I removed the damper so it basically runs right from the master cylinder to the slave cylinder and it functions fine.
Basically, the ***** isnt bleeding out, and I'm debating on removing this "connector"...
Old Feb 22, 2009 | 11:52 AM
pmohr's Avatar
No more Maximas...
The upper bleeder on the left strut tower, you mean?
Yea, the stock clutch line can be a PITA to bleed, and isn't the best design, IMO. Just replace it with a SS master-slave line from the GD section and be done with it.
Old Feb 22, 2009 | 12:36 PM
tbergma1's Avatar
pmohr, you beat me to answer all time, dang i'm slow.
Old Feb 22, 2009 | 12:46 PM
michaelp's Avatar
So I can ditch that "bleeder line" and have only the bleeder @ the slave?
Old Feb 22, 2009 | 01:01 PM
pmohr's Avatar
No more Maximas...
With the full SS (or other replacement) line, yes. With the stock line, there are so many places for air pockets to form that I'd leave the upper bleeder in place.
Old Feb 22, 2009 | 01:11 PM
michaelp's Avatar
I wasnt going to use any of the stock line except the rubber lines...
Old Feb 22, 2009 | 01:37 PM
pmohr's Avatar
No more Maximas...
Then yes, you can do that. Though if it's the original rubber line, I would replace that too, consider it preventative maintenance.
Old Feb 22, 2009 | 02:58 PM
michaelp's Avatar
Yeah, by original I meant the stock rubber lines, but they arent that old.
I got it going...holy **** 5 speeds are sooo much quicker than the automatics...
Old Feb 22, 2009 | 04:06 PM
michaelp's Avatar
AHAHAHAH...It was going great, then the pass CV shaft broke...
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
