dropping on tein s and have a question
Old Feb 25, 2009 | 10:55 AM
allensteiner21's Avatar
how far do i tighten the nut on top of the strut? till i can't turn it anymore?
Old Feb 25, 2009 | 11:08 AM
nissandrvr98's Avatar
that how i do it...but im SURE there is proper torque specs-anybody?
Old Feb 25, 2009 | 04:05 PM
i got it done in 5 hrs (no power tools )- 2 for the rear and 3 for the fronts. the fronts were a ***** to do...
anyways i know i need an allignment but my q is - what to expect? toe and/or something else?
Old Feb 25, 2009 | 05:02 PM
maximized98's Avatar
Addicted to the Org
You can expect a poor ride and blown struts and axles shortly. The alignment shop will fix you up though. They will make the adjustments you need.
Old Feb 25, 2009 | 05:54 PM
Bjs470's Avatar
Make sure you don't bust a nut though during the install
Old Feb 25, 2009 | 05:57 PM
S-Techs are WAY too aggressive for stock struts. Hope you have some performance 1s.
Old Feb 25, 2009 | 06:09 PM
ajm8127's Avatar
Look here:
http://forums.maxima.org/advanced-su...-question.html
and here:
http://forums.maxima.org/advanced-su...coilovers.html
Specifically post #33 in the second link.
I agree with ChrisMan. What you really need in this setup is shortened Konis, cause you just ate up just about all of your travel after droop in the front. I hope you at least got Illuminas or AGX's though. You got those, right?
Old Feb 26, 2009 | 12:18 AM
MrDicks95SE's Avatar
Offset Is Everything.
im guessing ~45lbs +/- 5lbs. you dont want it too tight but tight enough.
Old Feb 26, 2009 | 07:30 AM
i put the springs over hp's but didn't trim the bump stops - might extend the life of the struts till i get illuminas. also not worried about shock travel because all i drive is 25 miles a day on the freeway so nowhere to bottom out.
ajm - thx for the link
bjm - i think i busted both...i feel like after a hard workout
EDIT: scratch the illuminas - konis are pretty much the same price
Old Feb 26, 2009 | 09:30 AM
Snypa's Avatar
even with illuminas....s-tech is just no fun.
Old Feb 26, 2009 | 12:16 PM
wirelessdude04's Avatar
^^^ espeically with your illumnia's lol.. Get em fixed btw?
Old Feb 26, 2009 | 01:28 PM
Trim the bump stops and it should really help out A LOT.
Old Feb 26, 2009 | 02:21 PM
ajm8127's Avatar
I imagine if they are going to blow, it will be because of the increased spring rate on a rebound, not in a compression situation which is the only time bump stops would help. Not only that, but you must be practically resting on the bump stops now, hows the ride? Jarring?
There's something in the group deals section right now with Konis. Koni is also having a sale, and the guy gave me a pretty good price for a set. Read up on the strut inserts on the org though. Its not tricky, but there is a certain procedure to follow.
importrt is the user with the group deal, check that section on the forum. And get some Eibachs while you are at it as those Teins are just rice, IMO.
Old Feb 26, 2009 | 04:51 PM
i love the ride and how the car sits with the teins. the only thing they should fix is the spring rate on the rear - they feel a bit too soft. besides that no complaints.
Old Feb 27, 2009 | 10:15 AM
Snypa's Avatar
Sending then off this weekend.
Old Feb 28, 2009 | 06:36 AM
RA030726's Avatar
I'm nutty for Nissans
With Stechs untrimmed bump stops rest on the strut body, so you dont have any travel all ready. I had Stechs with CSK's and trimmed bump stops. This gave around an inch of travel. The ride was fine up front. The back however bottomed out all day long, even with trimmed stops.
Old Feb 28, 2009 | 10:10 AM
Crusher103's Avatar
i wouldnt go that far. thats pretty much damning everybody on coilovers that also give their cars aggressive drops
Old Mar 1, 2009 | 11:10 AM
ajm8127's Avatar
You can't really compare lowering springs on shocks and struts with coilovers. I am confused.
Old Mar 1, 2009 | 01:41 PM
thanks to all for advice but since this thread has no more purpose - close it please.
The Frye
Sep 2, 2021 11:03 AM
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
pears
Sep 18, 2015 05:25 AM
Johnny9595
Sep 3, 2015 05:18 AM
