is my replacement 5MT good?
#41
I have no clue what the sealant you use, perhaps its differant down south. At my work, for any oil/water related job we just use the good ol' grey permatex sealant.
Perhaps you used a sealant designed for water purposes(coolant)? I know the stuff that nissan wants use to use for the P71 cant be used for coolant, but it seals oil great.
http://www.permatex.com/products/Aut...sket_Maker.htm
it says that it works, but i think the delivery system leave a lot lacking and the time to do it is limited.
#42
another update...
got the trany in the car, closed up the entry wound .. tires and all.. got in the drivers seat and the shifter was stuck...
.../sigh
/almost_give_up
WAIT!! maybe i can pop out the gear selection sensor... i havent put fluids back yet...
i poped it off and saw the selector was set on te 1/2 rod.. but 3rd was engaged...
one long screwdriver and a little patience later i got it back into nutral and all is well...
adding fluids now via my ghetto rigged device ...
http://i82.photobucket.com/albums/j2...l/DSCN1736.jpg
test drive next...
/cross_fingers
.../sigh
/almost_give_up
test drive next...
/cross_fingers
#44
#46
It is a little cheaper but not much of a great deal imho if it has issues like he is saying. I was quoted a little more then that for a good rebuilt from a member here.
#47
#49
I can get rebuilts from FL for 900+shipping (VLSD for 1200+)
I shoulda gone that way, but i got some extreamly valuable experiance with this.
#50
as far as the motor... no its fine.
It only pulses the clutch (you can feel it in the pedal too) when its in gear. In nutral it is normal
#51
Could be just need to get the clutch broken in. Mine is kinda rough yet and I had all that done as well. BUT I did put a strong ACT clutch on mine as well and with that it jars the whole motor too.
maxinout93
08-20-2015 02:17 AM
MikesChevelle
08-06-2015 11:36 AM
