squeaky serpentine belt
the serpentine belt has been squeaking, especially on startup, for a while now and im tired of listening to it. I was going to replace it last fall but had no idea how to replace it. i cant even see most of it from the top so im jsut not sure how to even begin. is it a really big p.i.t.a?
(Ide rather not put any belt dressing on the belt cause i did that on another vehicle i owned and it ended up making things worse)
im sure there is a post somwhere about this but im in class right now and wanted to go to autozaone when im done for the day and dont have time to look through everything.
thanks in advance.
louis
thanks in advance.
louis
Well you don't have to remove the wheel, but it makes it easier.
Changing the PS belt is a PITA your first few times, but the AC/Alt belt is a piece of cake.
If you weren't able to see it, how did you know it needed replacing? loose does not always equal worn out.
1) check the tension, and 2) if its tight, ask yourself if you spilled any lubricants on it (ie, PS flush) and greased it up. If so, simply degrease and rinse.
Mine was squeeking, and when I went to tighten the tensioner (remove front pass wheel and the little fender liner dog door), where the tensioner bolt is supposed to sit in that bracket that gives the nut something to tighten against, the whole bolt was somehow bent out of place and resting against the outside of it. !?
Just hope your car wasn't previously owned by an evil giant who overtightened and stripped every bolt on your car.
well ill check to see if its just loose. it squeaks the most when its cold and then usually as it warms up it stops. i had a pinhole PS leak right at the bottom of the canister or at least that's what fire$tone told me when i went there for tires. i suppose that could cause the squeak but idk. all my cars seem to have a problem w/ the squeaking belts.
For actual specs:
Or how do I know if it's too loose or tight?
Too tight.... Something breaks...
That's how i figured it out!!! JUST REMEMBER!!!! LEFTY LOOSENS THE BELT!!!! RIGHTY TIGHTENS THE BELT!!!! It has opposite threading on the tensioner stud!!!
guys help me out with this...is it true about the opposite threading????...so i need to do the opposite?????? im having problems with a VERY LOUD squeaking at start up and when i turn on heat
05' MaximaMan
10-08-2017 06:36 PM
RWCreative
09-21-2015 11:01 AM
