OBDII -- Consult / What's New?
Old Apr 21, 2009 | 02:12 PM
gallilaw's Avatar
Is there an OBDII scanner worth buying for a 1998 Max?
And did anyone come up with a useful Consult emulator (that operates from a laptop)?
I have searched for recent news on these questions, but most of the stuff I found seems to be out of date.
Thanks.
Old Apr 21, 2009 | 02:16 PM
Kevlo911's Avatar
Kevlo for President
4th gens do not have a savable memory so no.
Doh, I thought he meant to program.
Code scanner, than differ. It will work
Old Apr 21, 2009 | 02:19 PM
pmohr's Avatar
No more Maximas...
Any old OBD-II code reader will do.
Are you just trying to read codes, or...what?
Old Apr 21, 2009 | 02:34 PM
modenaf1's Avatar
I just have one of those cheap 30 dollar Chinese ELMscan 327 OBD2 to USB adapters from Ebay and it works alright. Every now and then it crashes and I lose my connection to the ECU, but it gets the job done albeit a bit slowly (it only reads about 3 or 4 parameters a second, but I tried it on a newer car and it read 20, so I assume that is a limitation of the OBD2 bus on our 4th gens).
Old Apr 21, 2009 | 02:36 PM
pmohr's Avatar
No more Maximas...
Indeed, the A32 DLC is slow.
Old Apr 21, 2009 | 03:05 PM
allensteiner21's Avatar
dude...post #9: http://forums.maxima.org/4th-generat...solidated.html
i'll give you a good deal and it reads a **** ton of parameters. data logging doesn't work - loses connection to the ecu - due to an old design or my weak laptop.
Old Apr 21, 2009 | 03:19 PM
gallilaw's Avatar
I want a reader if all we can do is read from the 1998 link, and I want something more if there is any more we can do.
Other than mortgaging my house to buy an authentic Consult, what's the current best alternative that provides good functionality at reasonably low cost?
I am not trying to hypertune the car; just to diagnose problems, make reasonable adjustments (if possible) to basic systems, and and keep it running smoothly for the rest of my life -- assuming I am able to get it back on the road again, of course.
Best wishes.
Old Apr 21, 2009 | 03:41 PM
download the software i'm running with my cable from:
www.eformance.info/consult1209.zip
install and open, close the "main menu" and click "view" then "engine log" and it'll show you preset parameters you can monitor - there's more to choose from - also works as a code reader etc.
i'll give it away for $50 shipped - just for you
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
lummyrob
Sep 2, 2015 12:31 AM
hokiemax
Aug 19, 2002 08:00 AM
woosh
May 22, 2002 11:42 AM
