Automatics racing
Old Nov 22, 2001 | 04:51 PM
95maxrider's Avatar
Lightly modded
Automatics racing
Unfortunately, I own an automatic Maxima, and I've been wonder what some tips are for getting the best 1/4 I can get. Any tips?
Old Nov 22, 2001 | 04:53 PM
NYCe MaXiMa's Avatar
Re: Automatics racing
More info needed...
how much are you willing to spend????
are you looking for just tips on a better launch etc?
btw, try the "Search" link in the upper right hand corner, you'll find a million answers to your question
Old Nov 22, 2001 | 04:58 PM
95maxrider's Avatar
Lightly modded
Yeah, I'm trying to get launch tips.
Old Nov 22, 2001 | 05:54 PM
clee130's Avatar
When light turns green, take right foot off brake and place on gas pedal. Step down on gas pedal. Keep stepping on gas pedal.
Old Nov 22, 2001 | 05:59 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Old Nov 22, 2001 | 06:56 PM
KiLIAkLoWn's Avatar
Old Nov 22, 2001 | 07:34 PM
MAXIPADMAN's Avatar
I'll scan it later... but this is what I did! First of all, I shift, 1, to 2, to overdrive. that means when u put it in D, keep overdrive off. right before u start goin, for about 30 seconds, run the heat on full blast to the inside of the cabin. that gets the heat out of the engine. you want the engine as cold as possible, so way before the race, keep engine off, and open your hood. When you are at the lights, and ready to go, with your left foot press down on the breaks as hard as u can, and with your right foot gradually press the gas to about 3,000 rpms, or till your car barely stays in place, when its green, or 3rd yellow, whenever u go... doesnt really matter... let go of the break, and gradually press the gas to the floor. You dont want to floor it right away, or you'll get too much spin. shift to 2nd when you are at 6,000 still flooring it. same to drive.
good luck
...i copy/pasted this post from duplex in the 1/4 times sticky at the top of the 4th gen forum. I drive a 5 speed, although i thought this might be helpful to you in your quest for a better time.
ryan
Old Nov 22, 2001 | 08:15 PM
95maxrider's Avatar
Lightly modded
good luck
Thanks a lot man, thats more along the lines of the answer I was looking for.
ryan
Old Nov 22, 2001 | 08:51 PM
buss95max's Avatar
shifting won't help.
light turns green. put ur foot on the gas.
Old Nov 22, 2001 | 08:54 PM
Craig Mack's Avatar
You are right. Off the line first or 2nd doesn't give anymore power. Now, when you drive a lil when it's in 1 or 2nd and it gets high in the revvs, then you have some SERIOUS power! BUT, it wastes a TON of gas, and is HARD on your engine! And if you try manually shifting, dont take your foot off the gas! When you shift from 1--->2--->D your not really shifting. All your doing is telling the computer when to shift. And yes, it still has the stupid automagic delay.
So unless you get a tranny swap, let the tranny do itz thang.
Old Nov 22, 2001 | 09:01 PM
buss95max's Avatar
if its street racing, an automatic can easily beat/hang with a 5spd...
Old Nov 22, 2001 | 09:25 PM
Craig Mack's Avatar
Yea...I wouldn't race in traffic tho. It's dangerous.
Old Nov 23, 2001 | 08:28 AM
clee130's Avatar
Although torque braking might help a little also.
If anything, it'll give you a slightly better reaction time.
Along with the "Look mommy, I'm pretending to have a 5 speed!" look.
Old Nov 23, 2001 | 09:07 AM
95maxrider's Avatar
Lightly modded
Do you guys know if a tranny chip will mess up my car more than it helps? What about a regular power chip?
Old Nov 23, 2001 | 09:12 AM
clee130's Avatar
There's Don's VB mod: http://www.mobiletek.net/vb.html and http://forums.maxima.org/showthread.php?threadid=870
And then there's also the Gforce ECU: http://forums.maxima.org/search.php?...der=descending
Old Nov 23, 2001 | 09:17 AM
Mad Dhan's Avatar
good luck
ryan
uhh, leaveing your car off before a race(shifting at high rpms) or racing when engine/oil temp has not warmed up to operating temp does damage to your cars engine. Cool air is better yes, but not cool engine.
Old Nov 23, 2001 | 11:09 AM
MaximaRversion2
use left foot to hold the brake , use right foot to push gas , rev to 1500-1700 rpm , when light is green let go of brake , slam on gas , if wheels spin , let them , theyll stop spinning really quick , if you have good tires.
Old Nov 23, 2001 | 11:48 AM
MAXIPADMAN's Avatar
YEA, but my flux capacitor might overheat due to the extremely violent gamma rays because of the engine coolant leak!
just kidding... Yes your engine has to warm up so that the oil can coat your engine internal parts with a film. If its not the right temperature the film will break and you will have metal to metal contact. This is why synthetic oils are better, but still cant protect agains driving your car hard after a cold start.
Old Nov 23, 2001 | 12:45 PM
Craig Mack's Avatar
ECU's aka 'Superchips' have been known to give certain cars like 35hp. But I havent seen the facts on that. I don't think it does even 1/3rd of that to the Maxima.
Stupid VQ. Why did Nissan have to make it so damn great.
MaxStock
Dec 5, 2016 05:19 PM
ef9
Oct 4, 2015 08:43 AM
Andy29
Sep 29, 2015 05:32 AM
MplsMadMan
Sep 11, 2015 07:54 AM
