HELP! HID bulbs blown???
Old May 13, 2009 | 06:14 PM
mastajonjon's Avatar
Hi,
I accidentally left my hid headlights on and when I came out from class, my battery was dead. I had my car jumpstarted and now my hids don't work. I have a '99 maxima sel and I'm very upset. The weird thing is that my passenger side bulb worked at first but after turning them on and off to hopefully get the driver side working, they both don't work now. any suggestions?
I checked my headlight fuses under the hood. any other ideas would be appreciated...
Old May 13, 2009 | 07:25 PM
kzoosho's Avatar
Sounds more to be fried ballasts than blown bulbs.
Old May 13, 2009 | 09:19 PM
pmohr's Avatar
No more Maximas...
That's what I would assume as well.
OP: How are they hooked up...plug and play kit, or using a relay switched off of the stock headlight harness?
Old May 15, 2009 | 10:33 PM
i just had the plug and play kit hooked up to the stock harness...
I haven't had the chance to check my bulbs or ballasts, but I was needing info on how to check other things about my car that would maybe get it working again...
any other info is greatly appreciated...
has this ever happened to other ppl who owns an hid kit?
Old May 15, 2009 | 11:18 PM
ImmaSquashYou's Avatar
umm.....ok....lets see..sorry if i feel like this is a dumb question...anyways. to help you out. Hook up your stock bulb, see if they work, if they do, then its your bulb or ballasts. How to check it the ballasts work..get working bulbs....how to see if a bulb works, get a working ballast. DOH!!! but obviosuly you cant cause non of them work sooo....do a continuity check on the bulb, if there is continuity that means the bulb MOST likely 99.9% isn't the problem and is the ballast. How do you check if the ballast is working?? that i'm not really sure of except to plug in a working bulb
Old May 16, 2009 | 05:05 AM
bksmax11203's Avatar
hey, check and make sure that you don't have your high beams on..... cuz that happened to me and it turned out that they were on... and most people that put hids in their cars don't run the high and low ones. just the lows so when the high beam is on, the hids will cut out
Old May 16, 2009 | 10:39 AM
Snypa's Avatar
...this shud do you good.
Old May 16, 2009 | 08:45 PM
If you need a new kit, PM me.
Old May 16, 2009 | 09:33 PM
JtzMax's Avatar
Whatchyou say?
If you need a good harness, PM me. (ya know, relays, diodes, fuses ... the like)
Sorry this happened to ya, I would say it's likely your ballasts, but who knows.
Old May 17, 2009 | 10:55 AM
thanks all, i still haven't had a chance to check anything out...just driving during the day only...I still have 1 more final tomorrow, so i'll be checking things out prolly tomo afternoon. still have my fingers crossed, cuz I'd hate to buy a new kit over leaving my lights on!!!
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
knight_yyz
Nov 1, 2015 01:34 PM
Noela
Sep 26, 2015 08:22 AM
